Ethernet IPPT problems about LAN with RM500Q-GL modules
I’m a student focusing on industrial control using 5G, and I’m building a private 5G network to enable communication between two PLCs using Quectel RM500Q-GL modules.
My current network topology is as follows:
【PLC1(192.168.0.1)—Ethernet Cable–RM500Q-GL1(10.45.0.101)—Wireless—5GC (SDR)—Wireless—RM500Q-GL2 (10.45.0.102)—Ethernet Cable—PLC2(192.168.0.2)】
Current status:
  • Successfully established a private 5G network
  • Both RM500Q-GL modules connect to the network and obtain IP addresses (10.45.0.100 and 10.45.0.101)
  • The modules can ping each other and access both the gateway (10.45.0.1) and the internet
  • Each PLC has a fixed IP address (192.168.0.1 and 192.168.0.2) and connects to its respective 5G module via Ethernet
  • The PLCs cannot communicate with each other
## Problem Description
  1. Inconsistent AT Command Documentation: The responses from AT+QMAP=? and AT+QETH=? commands don’t match the official documentation. Some features mentioned in the documentation aren’t supported by the modules, while other supported features aren’t documented.
  2. Unclear Network Configuration Mode: It’s difficult to determine which mode (IP passthrough, router mode, bridge mode) is appropriate for enabling PLC-to-PLC communication.
  3. Confusing Routing/Bridging Functions: The AT+QETH=“routing” command exists but its purpose is unclear. The parameter format is restricted to AT+QETH="routing",add,4,8.8.8.8,3, which only allows specifying a single IP address rather than a complete routing rule (source, destination, gateway, etc.).
  4. IPPT and RGMII Configuration Ambiguity: There are contradictions and unclear instructions regarding AT+QMAP=“MPDN_rule” configuration parameters for IP passthrough (IPPT) and RGMII settings.
  5. PLC Fixed IP Challenge: The PLCs use fixed IP addresses (192.168.0.1 and 192.168.0.2) and don’t seem capable of obtaining IP addresses assigned by the 5G network.
Requirements
I need to enable communication between two PLCs with fixed IP addresses (192.168.0.1 and 192.168.0.2) through the RM500Q-GL modules over a private 5G network.
Specific questions:
  1. Which mode (IP passthrough/router/bridge) is most suitable for this scenario?
  2. What is the correct configuration for the RM500Q-GL modules to enable inter-PLC communication?
  3. Do the modules support sufficient routing capabilities to allow forwarding between different subnets?
  4. Are additional network devices (like routers) needed to accomplish this?
Currently, each module works normally in isolation for HTTP/TCP/UDP and ping functionality, but I cannot achieve cross-module communication between the PLCs.
Any help or suggestions from Quectel experts would be greatly appreciated!
RM500Q-GL 5G模块PLC通信问题求助
背景
我正在搭建一个私有5G网络环境,使两台PLC通过5G模块进行通信。目前网络拓扑如下:
【PLC1(192.168.0.1)—以太网—模块1(10.45.0.x)—无线—5GC—无线—模块2 (10.45.0.y)—以太网—PLC2(192.168.0.2)】
  • 已成功搭建私有5G网络,两台RM500Q-GL模块可以获取IP地址(10.45.0.100和10.45.0.101)
  • 模块可以互相ping通,也能访问网关(10.45.0.1)和互联网
  • PLC分别使用固定IP地址192.168.0.1和192.168.0.2,通过以太网连接到5G模块
  • PLC之间目前无法通信
问题描述
  1. AT命令与文档不匹配:模块返回的AT+QMAP=?和AT+QETH=?命令结果与官方文档不符,部分功能未在文档中说明,部分文档中的功能模块不支持。
  2. 网络配置混乱:很难确定应该使用哪种模式(IP透传、路由模式、桥接)来支持PLC通信。
  3. 路由/桥接功能不明确:AT+QETH="routing"命令存在但用途不明,参数格式限制为AT+QETH="routing",add,4,8.8.8.8,3,只能指定单一IP而非完整路由(源地址、目标地址、网关等)。
  4. IP透传与RGMII配置模糊:关于IPPT(IP透传)和RGMII的AT+QMAP="MPDN_rule"配置参数存在歧义。
  5. PLC固定IP难题:PLC使用固定IP地址(192.168.0.1和192.168.0.2),似乎无法获取5G网络分配的IP地址。
需求说明
我需要实现两台固定IP地址(192.168.0.1和192.168.0.2)的PLC通过连接到RM500Q-GL模块的方式,在私有5G网络中实现相互通信。
具体问题:
  1. 应该使用什么模式(IP透传/路由/桥接)最适合该场景?
  2. 如何正确配置RM500Q-GL实现PLC之间的通信?
  3. 模块是否支持足够的路由功能允许不同子网之间的转发?
  4. 是否需要额外的网络设备(如路由器)来辅助实现?
目前,单独测试每台模块均可正常使用HTTP/TCP/UDP和ping功能,只是无法实现PLC之间的跨模块通信。
感谢专业人士提供的任何帮助和建议!
Comment for views :+1: :+1: :+1:
Dear @Paulwie
Sorry about this, we don’t have more experience about this, hope other guys can help you.You can try to configure the routing rules in the 5G core network to map the 192.168.0.1/24 traffic of the PLC to the 5G subnet.
(post deleted by author)
Thank you for reply, at least you could clarify the difference between MPDN’s IPPT mode and RGMII’s IPPT mode, since I don’t really understand why there’s two mode of Ethernet on this chip, namely RGMII and PCIe enabled by MPDN and selected driver .
目前如果想实现两个PLC通过模块的透传直接获得核心网下发的IP,应该采用哪种透传模式?是RMGII还是通过MPDN实现的PCIE模式?对于两种驱动(r8125/r8168)的选择有没有讲究?感谢解惑。
Dear @Paulwie
Sorry, 我们没有相关的经验,只能提供相关指令参考。
您可以尝试RGMII,看是否满足您的需求。两种驱动(r8125/r8168)根据您的PHY类型选择。
Thank you nonetheless for your help.
