Hey Quectel team and friends,
I have a EM12-G, to be precise a EM12GPA-512-MSFT.
This modul was supposed to run on a FreeBSD-based firewall.
- When I first connected on FreeBSD the connection was stuck after initial connect. I was not able to send an AT command
- Then I got an USB to M.2 adapter and was connecting to my Windows computer. I was able to query the module and could send AT commands as expected. However, I was not able to update to a later MSFT-Firmware via DM port
- Then I connected the USB adapter to the FreeBSD machine and I was also able to query the modem and send AT commands
- Then I inserted a SIM card and was back to start. Connection to modem hang immediately.
- I removed the SIM Card, but no change
- I connected the modem back to the Windows machine, but all of a sudden also this connection was not working anymore. However, surprisingly I was able to update the firmware (although I could not check back with QNavigator or QCom due to the other issue)
- I also tried another windows and linux machine but no success
- The modem itself is recognized and also all com ports are available but it is just not connecting.
I am a bit puzzled what can cause this connection issue. Is this a hardware thing?
Thanks!
Chris
Maybe you can show some logs or screenshot.
It seems like the USB connection is not stable.
Please see some screenshots attached. As I can only add one file per message, I put them into a pdf document.
I am using QNavigator and QCom for connection test. And as said: This worked once.
On other systems I can observe the exact same: Connection hangs once opening the port.
screenshots.pdf (423.6 KB)
From this picture, it seems that the AT is not working. I suggest you check the hardware connection first. You used an M.2 to USB interface, can you show it to me? Have you tried to test it on another PC?
Plese see attached the adapter being used (antennas have been temporarily disconnected):
Same behaviour on different PCs.
And same behaviour in a “native” M.2 slot on a Mainboard directly.
What I noticed though: Device Manager is continuously refreshing when the module is attached. This indicates indeed a low level connection issue.
Thanks for taking care!
I am not sure which usbnet mode it is. Maybe you have tried the wrong windows driver.
Normally with only the USB connection I think the power supply is not enough.
There are two variant: MSFT2 & MSFT3 with different pid & vid
delete all quectel drivers and let windows install…
read similar topics (vid & pid issue).
When AT commands were still working, I set
AT+QCFG=“usbnet”,2
I was also using the additional usb-c power, but does not change anything.
Mine is neither MSFT2 nor MSFT3 it is just MSFT.
When I remove all drivers, the refreshing in device manager is gone, which clearly links it to the driver.
But, Windows 10 does not have any driver for the device. So, I would need to install some kind of quectel drivers. Any suggestion? ;)<
Thanks for your help!
