Eg916q-gl factory reset
I am using eg916q-gl module for lte connection for a embedded device. I tried to connect it with the ubuntu in my laptop. At first I was able to connect it by running quectel-CM in the linux pc. But I am not sure what I have done it led to automatic connection of the modem whenever i connect the pc with the quectel module.
Can someone explain what could have caused it?
How to reset the configuration or reset the module?
Pls check your configuration with AT+QCFG=“usbnet” command.
if it is EMC,it will be auto connect.
