Thank you, the new file works. Much appreciated
Hi Isaac,
Can you please send me the EG915N windows drivers as well?
Best Regards,
Charles
Thanks herbert.pan-Q.
I see it’s a later version than from the website, 5.0.1.6 vs 5.0.1.1 from website.
My problem is I still don’t get the “Quectel USB MI05 COM Port” to access the QuecPyton via QPYcom.exe.
Can you let me know how to get the driver for the “Quectel USB MI05 COM Port” ?
Regards,
Charles
pls provide your screenshot
Please provide a screenshot of your module or development board
Problem solved the module had the incorrect firmware on and I was supplied the correct firmware and now it works.
Regards,
Charles
Could you please send the Driver file of EG915N-EU also to me . Win 10
I have sent it to your email,pls try
Thank you. Now it works.
Hello
I’ve unilstalled any previous drivers, restart Win11, then make clean install of provided drivers from setup file. Restarted one more time and connected Dev Kit - no effect - still it’s not recognized
Any combination of manually adding the driver from the program files/quectel subfolders also doesn’t change anything
Can you try another PC?
No, it’s not possible. Problem is in the driver as it’s not recognized as proper one. The .INF files does not handle EG915N-EU device. I know VID and PID is the same in Quectel but the config is different for each module
Device firmware version: EG915N
Revision: EG915NEUAGR03A08M16
