Since it go to this mode, then you can run the QLog
QLog -s dump
There will be dump log in the folder dump.
QLog -s dump
It creates another folder in the folder dump, but there it’s empty…
root@RG-4085:/usr/src/QLog#
root@RG-4085:/usr/src/QLog# ./qlog -s dump
[000.000] Version: QLog_Linux_Android_V1.5.18
[000.000] will use filter file: built-in filter 0
[001.104] Find [0] idVendor=2c7c, idProduct=0125, bNumInterfaces=1, ttyDM=, ttyGENERAL=, ttyTHIRD=, busnum=003, dev=008, usbdevice_pah=/sys/bus/usb/devices/3-1.3
[001.104] open /dev/bus/usb/003/008 dm_usbfd = 3
[001.104] qlog_usbfs_read ( dm ) enter
[001.105] Press CTRL+C to stop catch log.
[001.105] kfifo_alloc [0] = 5
[001.105] catch dump for mdm chipset
STATE ← SAHARA_WAIT_HELLO
[002.106] poll() = 0, errno: 61 (No data available)
Failed to read complete bytes. Only read upto 0 bytes
← SAHARA PKT 0000: 01 00 00 00 30 00 00 00 …0…
RECEIVED ← SAHARA_HELLO_ID
RECEIVED ← SAHARA_MODE_IMAGE_TX_PENDING
Unexpected module state: 0
[002.106] ql_usbfs_read n = -1, errno: 108 (Cannot send after transport endpoint shutdown)
[002.106] kfifo_free [0] = 5
[002.106] qlog_usbfs_read ( dm ) exit
[002.107] close_fds exit
root@RG-4085:/usr/src/QLog# ls -l dump
total 4
drwxr-xr-x 2 root root 4096 Jun 14 13:01 dump_20240614_130158
root@RG-4085:/usr/src/QLog# ls -l dump/dump_20240614_130158/
total 0
Hi, this is still not resolved. What is the next step?
How can I get a working dump? Or in another way exit the broken QHSUSB__BULK mode?
To explore the possibility that it’s a damaged module, I’ve now obtained a second module, same model, same FW version.
But exactly the same thing happens.
Please contact Quectel’s local technical support and sales on behalf of your company.
It is not a simple issue that we can solve it here.
