EG25-G GPS issue
I`m currently using the EG25-G.
Our module was working well however out of a sudden it stopped getting GPS data.
I found that other people had similar issues, like in this forum:
However solution is not clear.
From the logs, I have good signal strength and satellites are visible.
Follows some logs from the device:
Module is active.
Retrieving GPS location…
Sending command: AT
Response: OK
Sending command: AT+CSQ
Response: +CSQ: 17,99
Sending command: AT+CFUN=1
Response: OK
Sending command: AT+QGPS=1
Response: OK
Sending command: AT+QGPSGNMEA=“GSV”
Response:
+QGPSGNMEA: $GPGSV,4,1,15,02,13,261,40,08,63,255,35,16,07,192,30,21,32,258,44,169*
+QGPSGNMEA: $GPGSV,4,2,15,07,10,61,139,13,03,358,14,07,336,157*
+QGPSGNMEA: $GPGSV,4,3,15,15,14,026,18,06,082,23,43,064,24,155*
+QGPSGNMEA: $GPGSV,4,4,15,27,58,170,30,08,310,32,04,139,159*
Sending command: AT+QGPSLOC?
Response: +CME ERROR: 516
Sending command: AT+QGPSLOC=2
Sending command: AT+QGPSEND
Response: OK
Sending command: AT+CGMR
Response: EG25GGBR07A08M2G
How to fix this issue?
This error code usually indicates that the GPS hardware connection is abnormal or the circuit design is not reasonable, I recommend you to check it carefully
ok @herbert.pan-Q . However from the logs, I have good signal strength and satellites are visible. So it doesn’t seem to be hardware-related.
Is there any firmware update that should be done? I read in another forum someone from Quectel sending a new firmware version to another person.
I have sent the latest firmware to you,pls check and try
ok thanks. I flashed the new firmware version (EG25GGBR07A08M2G_30.204.30.204). During this initial ~1 hour of test, it seems way more stable and I`m not getting the errors anymore from the GPS location.
Hello, can you please provide me the firmware EG25GGBR07A08M2G_30.204.30.204? Is it the latest version? I downgraded to 30.007.30.007 and now my EG25-G MINIPCIE device is not working
Hello, can you please also provide me with the latest firmware? I also have been trouble trying to get the gps to work on my end too. Thanks.
Please provide your current firmware version
AT+QGMR
Hi, same issue here with EG25GGBR07A08M2G_30.203.30.203.
I’m in clear sky, fresh xtra2 data. EG25 indicates 9 visible satellites but no fix after hours.
Can you please provide me the 204 firmware to test if there is some improvment with it ?
I am facing the same issue right now with EG25GGBR07A08M2G_A0.204.A0.204.
I’d like to test using the 30.204.30.204 that is being tested in this post.
Can you please provide me that firmware?
Thank you.
FYI, I spent a few days testing after updating the firmware on my module back in Dec24, but the issue persisted. It seems the firmware update didn’t resolve the problem, so I eventually gave up and opted for a different module instead.
