EG21-G MQTT over SSL/TLS with AWS IoT – SSL Configuration Causes QMTOPEN Failure
I am facing a persistent issue when connecting my Quectel EG21-G module to AWS IoT Core using MQTT over SSL/TLS. I have verified that my AWS configuration, certificates, and policies are fully correct, because the same certificates work perfectly on Node-RED and MQTT Explorer.
However, when using the EG21-G, the module behaves inconsistently depending on how SSL is configured.
Problem Description (Technical Details)
1. MQTT broker opens successfully only when SSL is NOT configured using QMTCFG
If I reset the module and simply do:
AT+QMTOPEN=0,"a2l9aypytopjpa-ats.iot.ap-south-1.amazonaws.com",8883
I get:
+QMTOPEN: 0,0
But when I attempt to connect:
AT+QMTCONN=0,"clientID"
I get:
+QMTCONN: 0,1
+QMTSTAT: 0,3   (Connection failed)
This means the port opens, but the SSL handshake fails afterward.
2. MQTT broker FAILS TO OPEN when SSL is configured using QMTCFG
If I configure SSL using:
AT+QMTCFG="ssl",0,1,2
OR
AT+QMTCFG="ssl",0,2
THEN execute:
I always get:
+QMTOPEN: 0,-1
So the module cannot even open the MQTT socket once SSL parameters are linked to MQTT using QMTCFG.
3. Certificates are correctly uploaded and detected
AT+QFLST
"rootca.pem",1189
"client.pem",1222
"private.pem",1677
I am using:
QSSLCFG index = 0
QMTCFG index = 0
4. SSL configuration that succeeds (only for QMTOPEN)
If I configure SSL but DO NOT link it with QMTCFG, like:
AT+QSSLCFG="sslversion",0,4
AT+QSSLCFG="seclevel",0,2
AT+QSSLCFG="cacert",0,"rootca.pem"
AT+QSSLCFG="clientcert",0,"client.pem"
AT+QSSLCFG="clientkey",0,"private.pem"
and then:
AT+QMTCFG="ssl",0,0
Then:
AT+QMTOPEN = successful
AT+QMTCONN = always fails (QMTSTAT 3)
5. Summary of the Issue
:check_mark: Certificates are correct
(Verified with Node-RED and MQTT Explorer)
:check_mark: EG21-G loads certificates successfully
:multiply: Problem occurs ONLY when SSL index is linked to MQTT using AT+QMTCFG
:multiply: QMTOPEN fails if QMTCFG SSL index = 1 or 2
:check_mark: QMTOPEN succeeds only when SSL is NOT correctly linked to MQTT
:multiply: SSL handshake always fails (AWS = TLS 1.2)
Hi Ali,
Before anything can you help to close the MQTT connection: AT+QMTCLOSE=0.
  1. Next maybe we can debug why you cannot connect to client:
    AT+QMTCONN=0,“clientID” // your “clientID” need to as unique as possible, it cannot be general name.
  2. Why AT+QMTOPEN=0,“a2l9aypytopjpa-ats.iot.ap-south-1.amazonaws.com”,8883?
    It could be because you are not close previous QMTOPEN since your =0 is same as previous without SSL. You can close by using AT+QMTCLOSE=0 as mentioned above or use new such as 1,2,3,4,5
hello dear Fazrul,
Thanks for addressing, I closed the server and reopen it but the problem persists.
I think this may a firmware update issue, as the old version may not support the current ssl configuration.
Hi Ali,
I will contact you separately for the firmware updates.
I will send you latest packages.
Sorry for late response.
Regards,
Fazrul Redzuan
