EG18-EA LTE disconnects when using Band 1+7
I am using Drei Austria and it uses Bands 1+3+7 for LTE. I have a lot of troubles with my data cards in Mikrotik LTE Routers with EG18-EA Modules. As long as I deactivate Band 1 or 7 everything works great. But as soon as both Bands are active (does not matter if with 3 combined or not) it looses Bands and disconnects every few seconds.
I tested 5G Modules, phones, other LTE devices with no Problems. Only with this EG18-EA Modules I see the problems with these two Bands.
Is there a known issue?
Blockquote
14:03:31 lte,async,event lte1: +CGEV: NW DETACH
14:03:31 lte,packet,raw lte1 mbim: wdm >>> recv #0
14:03:31 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
14:03:31 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
14:03:31 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 08000000
14:03:31 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
14:03:31 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
14:03:31 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
14:03:31 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
14:03:31 lte,packet,raw lte1 mbim: 00000000 00000000
14:03:31 lte,debug lte1 mbim: >>> N - connect: packet service
14:03:31 lte,packet lte1 mbim: status data:
14:03:31 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
14:03:31 lte,packet lte1 mbim: 00000000 00000000 00000000
14:03:31 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
14:03:31 lte,async,raw lte1: sent AT+QENG=“servingcell”
14:03:31 lte,async,raw lte1: rcvd +QENG: “servingcell”,“NOCONN”,“LTE”,“FDD”,232,10,1908400,457,3350,7,5,5,27AC,-101,-10,-72,16,12,80,-
14:03:31 lte,async,raw lte1: sent AT+QXPOWER
14:03:31 lte,async,raw lte1: rcvd +QXPOWER: 110,80,-32768,30
14:03:31 lte,async,raw lte1: sent AT+QNETINFO=“cmr”
14:03:31 lte,async,raw lte1: rcvd +QNETINFO: “cmr”,12,10,2,11
14:03:31 lte,async,raw lte1: sent AT+QNWCFG=“lte_l1_para”
14:03:31 lte,async,raw lte1: rcvd +QNWCFG: “lte_l1_para”,14,4,4,12
14:03:31 lte,async,raw lte1: sent AT+CSQ
14:03:31 lte,async,raw lte1: rcvd +CSQ: 21,99
14:03:31 lte,packet,raw lte1 mbim: 02000000 20000000 8085b50d 00000000
14:03:31 lte,packet,raw lte1 mbim: 809e4730 00000000
14:03:31 lte,packet lte1 mbim: 00000000 02000000 20000000 8085b50d
14:03:31 lte,packet lte1 mbim: 00000000 809e4730 00000000
14:03:31 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
14:03:32 lte,async,event lte1: +CGEV: NW DETACH
14:03:32 lte,packet,raw lte1 mbim: wdm >>> recv #0
14:03:32 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
14:03:32 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
14:03:32 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
14:03:32 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
14:03:32 lte,packet,raw lte1 mbim: 00000000 00000000
14:03:32 lte,debug lte1 mbim: >>> N - connect: packet service
14:03:32 lte,packet lte1 mbim: status data:
14:03:32 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
14:03:32 lte,packet lte1 mbim: 00000000 00000000 00000000
14:03:32 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
14:03:32 lte,packet,raw lte1 mbim: 02000000 20000000 8085b50d 00000000
14:03:32 lte,packet,raw lte1 mbim: 809e4730 00000000
14:03:32 lte,packet lte1 mbim: 00000000 02000000 20000000 8085b50d
14:03:32 lte,packet lte1 mbim: 00000000 809e4730 00000000
14:03:32 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
14:03:33 lte,async,event lte1: +CGEV: NW DETACH
14:03:33 lte,packet,raw lte1 mbim: wdm >>> recv #0
14:03:33 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
14:03:33 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
14:03:33 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
14:03:33 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
14:03:33 lte,packet,raw lte1 mbim: 00000000 00000000
14:03:33 lte,debug lte1 mbim: >>> N - connect: packet service
14:03:33 lte,packet lte1 mbim: status data:
14:03:33 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
14:03:33 lte,packet lte1 mbim: 00000000 00000000 00000000
14:03:33 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
14:03:33 lte,packet,raw lte1 mbim: 02000000 20000000 8085b50d 00000000
14:03:33 lte,packet,raw lte1 mbim: 809e4730 00000000
14:03:33 lte,packet lte1 mbim: 00000000 02000000 20000000 8085b50d
14:03:33 lte,packet lte1 mbim: 00000000 809e4730 00000000
14:03:33 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
14:03:34 lte,async,raw lte1: sent AT+QENG=“servingcell”
14:03:34 lte,async,raw lte1: rcvd +QENG: “servingcell”,“NOCONN”,“LTE”,“FDD”,232,10,1908400,457,3350,7,5,5,27AC,-101,-8,-74,17,12,210,-
14:03:34 lte,async,raw lte1: sent AT+QXPOWER
14:03:34 lte,async,raw lte1: rcvd +QXPOWER: 90,210,-32768,30
14:03:34 lte,async,raw lte1: sent AT+QNETINFO=“cmr”
14:03:34 lte,async,raw lte1: rcvd +QNETINFO: “cmr”,11,0,3,2
14:03:34 lte,async,raw lte1: sent AT+QNWCFG=“lte_l1_para”
14:03:34 lte,async,raw lte1: rcvd +QNWCFG: “lte_l1_para”,0,4,2,11
14:03:34 lte,async,raw lte1: sent AT+QRSRP
14:03:34 lte,async,raw lte1: rcvd +QRSRP: -102,-103,-104,-106
14:03:34 lte,async,raw lte1: sent AT+QNWCFG=“lte_rx_power”
14:03:34 lte,async,raw lte1: rcvd +QNWCFG: -71,-72,-75,-73
14:03:34 lte,async,raw lte1: sent AT+QCAINFO
14:03:34 lte,async,raw lte1: rcvd +QCAINFO: “pcc”,3350,100,“LTE BAND 7”,1,457,-101,-9,-71,17
14:03:34 lte,async,raw lte1: rcvd +QCAINFO: “scc”,525,75,“LTE BAND 1”,1,72,-99,-10,-79,0
14:03:34 lte,async,raw lte1: rcvd DL
14:03:34 lte,async,event lte1: +CGEV: NW DETACH
14:03:34 lte,packet,raw lte1 mbim: wdm >>> recv #0
14:03:34 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
14:03:34 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
14:03:34 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
14:03:34 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
14:03:34 lte,packet,raw lte1 mbim: 00000000 00000000
14:03:34 lte,debug lte1 mbim: >>> N - connect: packet service
14:03:34 lte,packet lte1 mbim: status data:
14:03:34 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
14:03:34 lte,packet lte1 mbim: 00000000 00000000 00000000
14:03:34 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
14:03:35 lte,packet,raw lte1 mbim: wdm >>> recv #0
14:03:35 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
14:03:35 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
14:03:35 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
14:03:35 lte,packet,raw lte1 mbim: 02000000 20000000 8085b50d 00000000
14:03:35 lte,packet,raw lte1 mbim: 809e4730 00000000
14:03:35 lte,debug lte1 mbim: >>> N - connect: packet service
14:03:35 lte,packet lte1 mbim: status data:
14:03:35 lte,packet lte1 mbim: 00000000 02000000 20000000 8085b50d
14:03:35 lte,packet lte1 mbim: 00000000 809e4730 00000000
14:03:35 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
14:03:36 lte,async,event lte1: +CGEV: NW DETACH
14:03:36 lte,packet,raw lte1 mbim: wdm >>> recv #0
14:03:36 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
14:03:36 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
14:03:36 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
14:03:36 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
14:03:36 lte,packet,raw lte1 mbim: 00000000 00000000
14:03:36 lte,debug lte1 mbim: >>> N - connect: packet service
14:03:36 lte,packet lte1 mbim: status data:
14:03:36 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
14:03:36 lte,packet lte1 mbim: 00000000 00000000 00000000
14:03:36 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
14:03:36 lte,packet,raw lte1 mbim: 02000000 20000000 8085b50d 00000000
14:03:36 lte,packet,raw lte1 mbim: 809e4730 00000000
14:03:36 lte,packet lte1 mbim: 00000000 02000000 20000000 8085b50d
14:03:36 lte,packet lte1 mbim: 00000000 809e4730 00000000
14:03:36 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
14:03:37 lte,async,event lte1: +CGEV: NW DETACH
14:03:37 lte,packet,raw lte1 mbim: wdm >>> recv #0
14:03:37 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
14:03:37 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
14:03:37 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
14:03:37 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
14:03:37 lte,packet,raw lte1 mbim: 00000000 00000000
14:03:37 lte,debug lte1 mbim: >>> N - connect: packet service
14:03:37 lte,packet lte1 mbim: status data:
14:03:37 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
14:03:37 lte,packet lte1 mbim: 00000000 00000000 00000000
14:03:37 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
14:03:37 lte,packet,raw lte1 mbim: 02000000 20000000 8085b50d 00000000
14:03:37 lte,packet,raw lte1 mbim: 809e4730 00000000
14:03:37 lte,packet lte1 mbim: 00000000 02000000 20000000 8085b50d
14:03:37 lte,packet lte1 mbim: 00000000 809e4730 00000000
14:03:37 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
14:03:37 lte,async,raw lte1: sent AT+QENG=“servingcell”
14:03:37 lte,async,raw lte1: rcvd +QENG: “servingcell”,“NOCONN”,“LTE”,“FDD”,232,10,1908400,457,3350,7,5,5,27AC,-101,-9,-71,16,14,110,-
14:03:37 lte,async,raw lte1: sent AT+QXPOWER
14:03:37 lte,async,raw lte1: rcvd +QXPOWER: 100,90,-32768,30
14:03:37 lte,async,raw lte1: sent AT+QNETINFO=“cmr”
14:03:37 lte,async,raw lte1: rcvd +QNETINFO: “cmr”,14,0,3,6
14:03:37 lte,async,raw lte1: sent AT+QNWCFG=“lte_l1_para”
14:03:37 lte,async,raw lte1: rcvd +QNWCFG: “lte_l1_para”,0,4,2,14
14:03:37 lte,async,raw lte1: sent AT+QRSRP
14:03:37 lte,async,raw lte1: rcvd +QRSRP: -102,-104,-140,-140
14:03:37 lte,async,raw lte1: sent AT+QNWCFG=“lte_rx_power”
14:03:37 lte,async,raw lte1: rcvd +QNWCFG: -73,-75,0,0
14:03:37 lte,async,raw lte1: sent AT+QCAINFO
14:03:37 lte,async,raw lte1: rcvd +QCAINFO: “pcc”,3350,100,“LTE BAND 7”,1,457,-102,-9,-73,16
14:03:37 lte,async,raw lte1: rcvd +QCAINFO: “scc”,525,75,“LTE BAND 1”,1,72,-99,-8,-82,0
14:03:37 lte,async,raw lte1: rcvd DL
14:03:38 lte,async,raw lte1: +CEREG: 1,“27AC”,“1908478”,7
14:03:38 lte,async,event lte1: +CGEV: NW DETACH
14:03:38 lte,packet,raw lte1 mbim: wdm >>> recv #0
14:03:38 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
14:03:38 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
14:03:38 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
14:03:38 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
14:03:38 lte,packet,raw lte1 mbim: 00000000 00000000
14:03:38 lte,debug lte1 mbim: >>> N - connect: packet service
14:03:38 lte,packet lte1 mbim: status data:
14:03:38 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
14:03:38 lte,packet lte1 mbim: 00000000 00000000 00000000
14:03:38 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
14:03:38 lte,packet,raw lte1 mbim: 02000000 20000000 8085b50d 00000000
14:03:38 lte,packet,raw lte1 mbim: 809e4730 00000000
14:03:38 lte,packet lte1 mbim: 00000000 02000000 20000000 8085b50d
Hi @Moravitz
Can I ask what firmware version you’re using?
