EG-25GL not switching to Verizon
I use a multi carrier sim, that works fine with EC-25AF modems, but when used in an EG-25GL modem, I am not able to set the carrier Verizon in manual mode.
AT+COPS=1,2,“311480” fails with
+CME ERROR: 30
AT+CEER
+CEER: 6,259
I can switch to AT&T just fine, but when setting to Verizon, connection drops and it goes back to AT&T.
see error below " requestSetProfile UXResult = 0x1, QMUXError = 0x51*
[12-31_07:07:01:524] WCDMA&LTE_QConnectManager_Linux&Android_V1.1.34
[12-31_07:07:01:528] quectel-CM profile[1] = soracom.io/sora/sora/1, pincode = (null)
[12-31_07:07:01:532] Find /sys/bus/usb/devices/1-1 idVendor=2c7c idProduct=0125
[12-31_07:07:01:532] Find /sys/bus/usb/devices/1-1:1.4/net/eth1
[12-31_07:07:01:536] Find usbnet_adapter = eth1
[12-31_07:07:01:536] Find /sys/bus/usb/devices/1-1:1.4/usbmisc/cdc-wdm0
[12-31_07:07:01:540] Find qmichannel = /dev/cdc-wdm0
[12-31_07:07:01:564] /proc/680/fd/7 -> /dev/cdc-wdm0
[12-31_07:07:01:568] /proc/680/exe -> /usr/sbin/quectel-CM
[12-31_07:07:03:576] cdc_wdm_fd = 8
[12-31_07:07:03:656] Get clientWDS = 5
[12-31_07:07:03:688] Get clientDMS = 1
[12-31_07:07:03:720] Get clientNAS = 2
[12-31_07:07:03:752] Get clientUIM = 2
[12-31_07:07:03:784] Get clientWDA = 1
[12-31_07:07:03:816] requestBaseBandVersion EG25GLGAR07A03M1G
[12-31_07:07:03:912] requestGetSIMStatus SIMStatus: SIM_READY
[12-31_07:07:03:912] requestSetProfile[1] soracom.io/sora/sora/1
**[12-31_07:07:03:944] requestSetProfile UXResult = 0x1, QMUXError = 0x51**
[12-31_07:07:03:976] requestGetProfile[1] soracom.io/sora/sora/1
[12-31_07:07:04:008] requestRegistrationState2 MCC: 310, MNC: 410, PS: Attached, DataCap: LTE
[12-31_07:07:04:040] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[12-31_07:07:04:104] requestRegistrationState2 MCC: 310, MNC: 410, PS: Attached, DataCap: LTE
[12-31_07:07:04:136] requestSetupDataCall WdsConnectionIPv4Handle: 0x86d96b20
[12-31_07:07:04:200] requestQueryDataCall IPv4ConnectionStatus: CONNECTED
[12-31_07:07:04:232] ifconfig eth1 up
[12-31_07:07:04:252] busybox udhcpc -f -n -q -t 5 -s /usr/share/udhcpc/htnice_4g.script -i eth1
[12-31_07:07:04:272] udhcpc (v1.22.1) started
[12-31_07:07:04:280] Setting IP address 0.0.0.0 on eth1
[12-31_07:07:04:308] Sending discover...
[12-31_07:07:04:336] Sending select for 10.187.3.228...
[12-31_07:07:04:368] Lease of 10.187.3.228 obtained, lease time 7200
[12-31_07:07:04:376] Setting IP address 10.187.3.228 on eth1
[12-31_07:07:04:392] Deleting routers
[12-31_07:07:04:400] Adding router 10.187.3.229
[12-31_07:07:51:720] requestRegistrationState2 MCC: 311, MNC: 480, PS: Detached, DataCap: UNKNOW
[12-31_07:07:51:752] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[12-31_07:07:51:752] ifconfig eth1 down
[12-31_07:07:51:816] requestRegistrationState2 MCC: 311, MNC: 480, PS: Detached, DataCap: UNKNOW
[12-31_07:07:51:816] requestSetOperatingMode(1)
[12-31_07:07:51:848] requestSetOperatingMode(0)
[12-31_07:07:52:200] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
[12-31_07:07:52:488] requestRegistrationState2 MCC: 310, MNC: 410, PS: Detached, DataCap: UNKNOW
[12-31_07:07:57:224] requestRegistrationState2 MCC: 310, MNC: 410, PS: Detached, DataCap: UNKNOW
[12-31_07:08:02:280] requestRegistrationState2 MCC: 310, MNC: 410, PS: Detached,
[12-31_07:08:37:672] requestRegistrationState2 MCC: 310, MNC: 410, PS: Detached, DataCap: UNKNOW
[12-31_07:08:37:672] requestSetOperatingMode(1)
[12-31_07:08:37:704] requestSetOperatingMode(0)
[12-31_07:08:37:992] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
[12-31_07:08:38:504] requestRegistrationState2 MCC: 310, MNC: 410, PS: Detached, DataCap: UNKNOW
AT+CPIN?
+CPIN: READY
AT+QGMR
EG25GLGAR07A03M1G_01.201.01.201
AT+CFUN?
+CFUN: 1
AT+CGDCONT?
+CGDCONT: 1,“IPV4V6”,“soracom.io”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“SOS”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,1
AT+CREG?
+CREG: 2,5,“6C00”,“C143F33”,7
AT+QCSQ
+QCSQ: “LTE”,70,-104,84,-15
AT+QNWINFO
+QNWINFO: “FDD LTE”,“310410”,“LTE BAND 66”,67086
AT+CGATT?
+CGATT: 1
Please help me understand the errors and why I cannot get the modem to switch to Verizon. Now if I take the sim to a EC25-AF modem, i can set it to Verizon. I confirmed the APN and username / password is correct.
Thank you
For verizon SIM card, please run the quectel-CM
quectel-CM -n 3
to specify the CID with PDN#3.
If you see some log like this it means that it is not registerred.
I find understand why same software and sane sim have different result with GL vs AF modem
Thank you for your reply. why do you say PDN#3 ? Is that not reserved for SOS?
my multi carrier sim from Soracom works on both Verizon and AT&T when used with a EC25-AF installed in the exact same hardware and software. When switching the module out with EG-25GL, it will connect in automatic mode with AT&T but when I set it to Manual Verizon as you see above in the log it does not connect.
But I know SIM card has this capability. Thank you
For Verizon SIM card, we have to set up data call with PDN#3 and so that we should run the quectel-CM
quectel-CM -n 3
But for AT&T we do not need to speicfy the PDN it would try the default PDN#1.
Hello Gman,
you may check if the EG25-GL has provider profiles enabled.
If yes, it would be best to deactivate provider profile selection and use the Generic profile when running a Soracom SIM.
AT+QMBNCFG=“autosel”,0
AT+QMBNCFG=“Select”,“ROW_Generic_3GPP”
AT+cfun=1,1
After restart it should look like this:
AT+QMBNCFG=“list”
+QMBNCFG: “List”,0,1,1,“ROW_Generic_3GPP”,0x05010820,201905141
The ‘,1,1,’ in front of the ROW_Generic means profile active & profile selected.
You adapt/delete APN settings as well:
AT+CGDCONT=1,“IP”,“soracom.io
AT+CGDCONT=2
AT+CGDCONT=3
