Yes this time i received the file and was able to download it.
However the image only contains the image files. Where is the manual for how to do the update and do i need any kind of tool to do that ?
I found some posts mentioning QFlash or QFirehose.
Where can i download that ?
I have sent Qflash and Qfirehose to you
Again i haven’t received anything.
Did you use the gmail address ?
If not please send it there again.
Can you provide another valid email address
I only have these 2 email address:
removed
removed
Last time i was able to receive the firmware you sent using SharePoint through the Gmail address.
If you can’t get that to work please figure out a solution on your end since i don’t have an infinite amount of email address or other places you can send things to me.
I have sent Qflash and Qfirehose to you again
Thanks. I received the files and was able to successfully update the firmware.
Can you please sent me the latest firmware too ?
The modem is currently running:
VERSION: EC25EFAR08A04M4G
Kindly, share with me!
