Questions:
May I have the latest firmware for EC25AFFA-MINIPCIE modems with version EC25AFFAR07A08M4G ?
Any suggestions for next debug steps to troubleshoot the inconsistent PPP dial-up behavior described below ?
I have 5 EC25AFFA-MINIPCIE modems and all are running firmware version EC25AFFAR07A08M4G.
Only 1 of 5 EC25AF modems is making a proper PPP connection. I need to figure out why the other 4 modems will not make a proper connection. All 5 systems are prepared identically.
Observations:
All 5 modems are registered on their home network (Verizon Wireless) as shown by at+cereg? returning +CEREG: 0,1
I can confirm that the local IP addresses shown by at+cgpaddr=1 matches the IP addr shown on the VZW device info portal.
All 5 modems have identical PDP contexts for cid=1 with the proper APN string.
All 5 modems report similar PDP Context Read Dynamic Parameters as shown by at+cgcontrdp. As expected, the only difference is the IP address assignment assigned to each.
Only 1 of the 5 modems is receiving an IP address after the ATD*99# dial-up to establish the PPP connection as idicated by the lwip log as “I (169545) esp-netif_lwip-ppp: Connected”. The other 4 modems will not have this log entry and will not perform the ESP IDF “modem_console” ping or httpget funtions.
I can not find any difference in the configuration of the 5 modems and do not understand why I can reliably make a PPP connection on 1 modem but not the other 4 modems.
All 5 modems are connected to identical ESP32-S3 host controllers running identical ESP-IDF firmware utilizing lwip’s native PPP support.
Respectfully,
David.
