My team is working on EC25 modems and as a customer need, we are looking for a way to restrict access to the modem via the USB. We want to disable adb access, but there should also be a provision to re-enable it when required. Please let us know the process and changes that need to be made in the kernel files.
Thanks.
Are you using a Quecopen or a standalone solution? Please share complete firmware version by AT+QGMR.
Hi Rodney,
Thanks for your reply.
I am using EC25E device and QuecOpen EC25EFAR06A12M4G_OCPU_20.200.20.200 for SDK and base FW.
Best regards.
Please try below command to disable adb.
at+qcfg=“usbcfg”,0x2C7C,0x0125,1,1,1,1,1,0,0
Hi Rodney,
Thanks for this solution. This works out for me. I just have a few final questions…
- If I were to disable the USB AT port, would I still be able to use the virtual AT port? And if no, then is there any other method to re-enable it?
- Among the other ports that are possible to disable (“diag”, “nmea”, “at_port”, “modem”, “rmnet”), will disabling any or all of them cause any trouble in re-enabling them?
Thanks and best regards.
What do you mean about virtual AT port? Are you using a Quecopen solution?
