Hi, Is it possible to connect to external network with F20?
For example I have a Wifi network in the area with SSID: xxx, can I connect to it?
Thanks,
Thanks,
Dear Saoron,
You mean you cant FC20 work in the STA mode, right? You can check the following document. Hopefully it is usefully to you. Thanks!
Quectel_EC2x&EG25-G_Wi-Fi_Application_Note_V1.1.pdf (421.9 KB)
Thank you,
Are all units have this in their firmware or only EG25? If not is there a way to upgrade the firmware?
Yes, all LTE module can support it now, not just EG25. But you may need to upgrade to the latest firmware. You can email to support@quectel.com to get it. Thanks!
