Hi
We have a large number of EC25-E modems deployed, and have noticed some inconsistent behaviour between them.
We would like to harmonize them on the latest stable firmware versions (currently they are running various)
Are you able to provide us with the latest stable firmware for the EC25-E as well as release notes showing what has changed between each release over the last few years?
The problem seems often to occur after the unit has been in an area with no reception - like a tunnel. Following this, it will sometimes not reconnect to the network even after a reset
Thanks. Do you know if any of the fixes in this release vs the version we were running might help with the problems we were seeing - namely a failure to recover when signal was lost then regained?
We also run a smaller number of EG25-G modems which have seen the same symptoms - is there a version of firmware we could/should use for them?
