Try to use with Verizon but is not regestring, but at&t and tmobile working do i need update?
Dear Sir,
For EC25AF module, it is better to use EC25AFFAR07A09M4G to test it. So please send email to support@quectel.com to get the firmware package and upgrade tool to flash the firmware. Thanks!
ok thanks i will contact them , do i need to register imei with verizon too ?
Dear Sir,
You can check the following document. Thanks!
How to register on VZW network v2.pdf (405.7 KB)
I did regester with Verizon , but no data only text and voLTE is working i did upgrade to EC25AFFAR07A09M4G
Any help ?
If you have registered on Verizon, it is better to provide debug log to us to analyze the reason. For upgrade firmware, please email to support@quectel.com to get it and upgrade tool. Then you can get support from local FAE, they will help you to fix your issue. Thanks!
How can i get debug log ?
