I have an E25G modem and I am trying to retrieve the lat/long from the GPS module. I am using the following commands:
root@ubuntu:/home/willthio/thio-thing# sudo mmcli -m 0 --command=AT+QGPS
error: command failed: ‘GDBus.Error:org.freedesktop.ModemManager1.Error.MobileEquipment.Unknown: Unknown mobile equipment error: 502’
root@ubuntu:/home/willthio/thio-thing# sudo mmcli -m 0 --command=AT+QGPSCFG
What am i doing wrong?
Thanks,
Will
Modem details:
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: fa9e98db61d3897b0ea1d105d70ac60fc6f6df29
Hardware | manufacturer: QUALCOMM INCORPORATED
| model: QUECTEL Mobile Broadband Module
| firmware revision: EG25GGBR07A08M2G
| carrier config: ROW_Generic_3GPP
| carrier config revision: 0501081F
| h/w revision: 10000
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 867652076499003
System | device: /sys/devices/platform/soc/fe980000.usb/usb1/1-1/1-1.1
| drivers: option, qmi_wwan
| plugin: quectel
| primary port: cdc-wdm0
| ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB2 (at), ttyUSB3 (at),
| wwan0 (net)
Numbers | own: 423647785631
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: connected
| power state: on
| access tech: lte
| signal quality: 73% (recent)
Modes | supported: allowed: 2g; preferred: none
| allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 2g, 3g; preferred: 3g
| allowed: 2g, 3g; preferred: 2g
| allowed: 2g, 4g; preferred: 4g
| allowed: 2g, 4g; preferred: 2g
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 2g
| current: allowed: 2g, 3g, 4g; preferred: 4g
Bands | supported: egsm, dcs, pcs, g850, utran-1, utran-4, utran-6, utran-5,
| utran-8, utran-2, eutran-1, eutran-2, eutran-3, eutran-4, eutran-5,
| eutran-7, eutran-8, eutran-12, eutran-13, eutran-18, eutran-19,
| eutran-20, eutran-25, eutran-26, eutran-28, eutran-38, eutran-39,
| eutran-40, eutran-41, utran-19
| current: egsm, dcs, pcs, g850, utran-1, utran-4, utran-6, utran-5,
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 867652076499003
| enabled locks: fixed-dialing
| operator id: 310410
| operator name: SORACOM
| registration: roaming
| packet service state: attached
3GPP EPS | ue mode of operation: csps-2
| initial bearer path: /org/freedesktop/ModemManager1/Bearer/0
| initial bearer ip type: ipv4v6
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
| sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0 (active)
| slot 2: none
Bearer | paths: /org/freedesktop/ModemManager1/Bearer/1
