EC21-AUX image corruption after 6k with mms
After uploading an image into RAM and adding to an MMS and sending the received image is corrupted.
If I send a small image 3k it looks fine.
If I send at around 6k it is corrupted.
If I send a 50k image it is not received and only the subject will come through.
I’m using minicom to upload the file with ASCIi as the upload protocol and none of the other choices (zmodem,ymodem,kermit…) appear to work.
Is there a maximum file size that the module can handle when creating thems pdu?
Any help on this would be great.
Okay.
All sorted via direct method outside of minicom.
