EC200U Version EC200UCNAAR03A13M08 , GNSS Fix Not Happening
Here’s a professional and detailed message you can paste in the forum to report the issue clearly and request support from Quectel or community members:
:receipt: Post Title:
EC200U Version EC200UCNAAR03A13M08 – GNSS Not Starting / No Fix
:puzzle_piece: Post Body:
I’m using a Quectel EC200U-CNAA module with the following firmware:
ATI
EC200U
Revision: EC200UCNAAR03A13M08
I’m trying to use the internal GNSS engine using the following AT commands:
AT+QGPS=1         → OK
AT+QGPS?          → +QGPS: 1
AT+QGPSLOC=2      → No response or timeout
AT+QGPSCFG?       → +CME ERROR: 501
AT+QGPSGNMEA="GGA" → No data
However, GNSS engine doesn’t seem to start properly. The response:
+QGPS: "firmware",0,0
…suggests the GNSS engine is not enabled or not supported in this firmware.
Can someone from Quectel or the community confirm:
Whether GNSS is supported in EC200UCNAAR03A13M08 firmware?
Any help or firmware upgrade info would be appreciated. Thanks!
Please send
AT+QGPSPOWER=1
also.
And if still not working maybe you can try the passive atenna.
Worked, thanks ! Can you mail me the updated AT command sheet or release note of this particular firmware version
dear @RoboShala @Bean.Wang-Q do you have this version of firmware?
Please send me i need it due to an error of AT+QTRPIN which response as +CME ERROR: 58
