Hello Quectel Support,
@herbert.pan-Q
I’m using a Quectel EC200A module soldered on a router running OpenWrt.
- Module: EC200A-AU
- Firmware: Revision EC200AAUHAR01A12M16 (from ATI)
- Current operating mode: USB CDC-ECM data interface acting as a CPE/router (OpenWrt gets DHCP on usb0 at 192.168.43.x, gateway 192.168.43.1)
- Desired mode: A direct modem interface (e.g., RNDIS/QMI/MBIM) or a way to enable bridge/passthrough to avoid double NAT
Given the hardware is integrated, I’m limited to AT commands over /dev/ttyUSB2 from OpenWrt. I attempted to query/change the USB mode with:
- AT+QCFG=“usbnet”? → ERROR
- AT+QMAP? → ERROR
Other related queries like AT+QCFG=“DATA_INTERFACE”? and AT+QCFG=“USBNETMODE”? also return ERROR.
Questions:
- Is it expected that this firmware (EC200AAUHAR01A12M16) does not expose AT+QCFG=“usbnet” (or equivalent) to switch between ECM/RNDIS/QMI/MBIM?
- Is there any supported method to change the data/USB mode or enable true IP passthrough/bridge on this firmware?
- If not supported, is there a recommended firmware variant or SKU for EC200A that enables usbnet mode selection or bridge/passthrough, suitable for OpenWrt integration?
Additional context:
- The module currently provides a private IP (192.168.43.x) and the cellular PDN is under CGNAT (100.64.0.0/10).
- We can send and receive standard AT commands (ATI, AT+QNWINFO, AT+COPS?, AT+CGPADDR).
- The goal is to avoid double NAT and/or integrate via QMI/MBIM from OpenWrt.
Thank you for your guidance!
