Driver for BG95M3 on Windows 11 as Parallels OS
I know this is probably pushing it a bit…
I have a BG95M3 module which I have installed the driver/Qcom/Qflash for and have updated the firmware and tested the module OK on a WIndows 11 PC.
I’d know like to repeat this setup on a Windows 11 installation running under Parallels on a Mac (given that there is no native MAC support).
I have tried the same driver that worked on the PC/Win11 combo but the devices remain stubbornly ‘un-drivered’ in Device Manager…
Before I give up, thought it was worth asking if anyone has had any success with this config? Thanks
pls try the driver what I have sent to you
Hi Herbert,
Many thanks for responding to my post, appreciated. I have tried the driver you have sent over and that yields the same result as per my origina post. Is there any other info I can provide to aid with the diagnosis?
I resend another driver, please try
Herbert - thanks for the updated driver. Same result, I’m afraid :(.
Then I think you can replace another PC and try again
Herbert - many thanks for your efforts in trying to resolve this. In the end, I used an FTDI cable connected to the main uart and use the USB for power only.
It’s all good now, I’m talking to my BG95 from my Mac :slight_smile:
