Does the BC660K-GL support roaming?
I’m trying to connect to a network using a BC660K-GL and a Hologram SIM. I have had success in connecting in the U.S., but I have not been able to connect the same devices to a network in Italy. Hologram says that they require that the device be setup to enable roaming. Setting a home network preference will not work.
https://support.hologram.io/hc/en-us/articles/360035697013-Writing-custom-firmware-for-your-device
Does the BC660K-GL support roaming? If it does support roaming and needs to be enabled, what sequence is required to enable it? How do I know if roaming is enabled?
Is there potentially another explanation for why the same device would connect in the U.S., but not in Italy?
Thanks,
Don
