Does RG520F-JO support LTE bands?
Enter a AT Command: AT+QNWPREFCFG="lte_band"
Result:
+QNWPREFCFG: "lte_band",0
Input exit to quit
Enter a AT Command: AT+QNWPREFCFG="nr5g_band"
Result:
+QNWPREFCFG: "nr5g_band",78
Input exit to quit
Enter a AT Command: ati
Result:
RG520F-JO
Revision: RG520FJOAAR05A03M4G_OCPU_LXA
Input exit to quit
Enter a AT Command: AT+QNWPREFCFG="lte_band",1:2:3:4:5:7:8:12:13:14:17:18:19:20:25:26:28:29:30:32:34:38:39:40:41:42:66:71
Result:
Input exit to quit
Result:
+QNWPREFCFG: "lte_band",1:2:3:4:5:7:8:12:13:14:17:18:19:20:25:26:28:29:30:32:34:38:39:40:41:42:66:71
Input exit to quit
Enter a AT Command:
I was able to add esim via lpa and succesfully added 3 global esim, but they support 4g only or 5g nsa. By default i received the module in 5g sa mode with band 78 enabled. So I want to know if i can get LTE working on this ? or is it not supported ? because i can add bands from
but maybe i am doing something wrong.
Dear @BlueNecko
In standard firmware, it supports LTE bands.
But your firmware version is RG520FJOAAR05A03M4G_OCPU_LXA, I am not sure if your supplier had changed some configurations.
