I am testing a BC660K-GL NBIOT module with a MULTI-IMSI SIMs, but it semes the module does not support it with the default configuration.
Should I set anything specific to enable the support for MULTI-IMSI for the BC660K-GL NBIOT module?
Thanks,
Thanks,
I am using BC660K, and I have not found a reliable way to use MULTI-IMSI.
The mechanisms for switching the IMSI is not working on NB-IoT.
And a SIM in BC660K is not able to receive updated roaming lists from operators - since SMS is not supported.
