[Document sharing]-DTU User Guides
Basic illustration
The aim of this article is to guide user how to develop DTU based on the QuecPython EVB of we Quectel.
Preparation
Insert SIM card into the NANO SIM card socket
Insert the antenna into the socket with “LTE” marked on the back of EVB and press it tight.
Connect the EVB to the PC via USB cable
For starting up device and downloading QPYcom, please refer to the link for more details.
Build QuecPython development environment
Load FW of DTU and configuration file to EVB
Compile configuration file in accord with demands after opening up the DTU folder hidden in code library.
Format and illustration of configuration file are displayed.
“plate”: 1, //Whether IMEI is added in the message
“password”: “123”, //Set password
“conf”: { //Set online connection
“1”: { //Channel serial number
//Set HTTP connection
“protocol”: “http”, //Connection type, fixed as http
“method”: “get”, //Method of request
“url”: “http://httpbin.org/get”, //Request url
“reg_data”: “”, //Fixed text attached
“timeout”: “”, //Timeout
“serialID”: 1 //Bound serial port (1-2)
“2”: {
//Set TCP&UDP connection
“protocol”: “tcp”, //Conncetion type. If it is tcp, fill it directly, while for UDP, it is the same way.
“ping”: “”, //Ping
“heartbeat”: 30, //Heartbeat duration
“url”: “220.180.239.212”, //Ruquest url
“port”: “8305”, //Port
“keepAlive”: 300, //Keepalive duration
“serialID”: 2 //Bound serial port
“3”: {
//Set mqtt connection
“protocol”: “mqtt”, //Connection type
“clientID”: “test_mqtt”, //Client ID
“keepAlive”: “”, //keep alive timeout
“url”: “mq.tongxinmao.com”, //url
“port”: “18830”, //Port
“cleanSession”: “0”, //Clean session
“subscribe”: {“0”: “/public/TEST/python”}, //Subscribe topic (multiple topics are supported)
“publish”: {“0”: “/public/TEST/python”}, //Publish topic (multiple topics are supported)
“qos”: “0”, //QoS
“retain”: “1”, //Reattach internally
“serialID”: “1” //Bound serial port
//Set Aliyun connection
“4”: {
“protocol”: “aliyun”, //Connection type
“type”: “mos”, //Set unique-certificate-per-device authentication/unique-certificate-per-product authentication
“keepAlive”: “”, // Keep alive timeout
“clientID”: " test_mos “, //Client ID
“Devicename”: " light01”, //Device name
“ProductKey”: " a1QNbCDxIWM ", //Product key
“DeviceSecret”: “0bceb8010ade0df2e6989982e63f7601”, //Device secret
“ProductSecret”: “”, //Product secret
“qos”: “1”, //QoS
“subscribe”: {“0”: “/a1QNbCDxIWM/light01/user/get”}, //Subscribe topic (multiple topics are supported)
“publish”: {“0”: “/a1QNbCDxIWM/light01/user/update”}, //Publish topic (multiple topics are supported)
“5”: {
//Set Tencent Cloud
“protocol”: “txyun”,
“type”: “mos”,
“keepAlive”: “”,
“clientID”: “test_tx_mos”,
“Devicename”: “Smart_test01”,
“ProductKey”: “H7MBLRYXN9”,
“DeviceSecret”: “89c7tXT3s3grZTr/YFjxSg==”,
“qos”: “1”,
“subscribe”: {“0”: “H7MBLRYXN9/Smart_test01/control”},
“publish”: {“0”: “H7MBLRYXN9/Smart_test01/event”},
“serialID”: “1”
“reg”: 1, //Transit registration message
“convert”: 0,
“version”: 100, //FW Version
“nolog”: 0, //Whether output log
“message”: {}, //Protocol message transparency
“uconf”: { //Set serial port
“1”: {
“baudrate”: “115200”,
“databits”: “8”,
“parity”: “0”,
“stopbits”: “1”,
“flowctl”: “0”
“2”: {
“databits”: “8”,
“parity”: “0”,
“stopbits”: “1”,
“flowctl”: “0”
“fota”: 1, //Whether enable fota
“pins”: [ //Enabled pio
“pio1”,
“pio2”,
“pio3”
“direction_pin”: {}, //The direction controlled by GPIO and the default direction
“apn”: [ //Set APN
“service_acquire”: 0, //Whether enble server to get parameter
“work_mode”: “command”, //Work mode
“auto_connect”: 1, //Auto-connect
“offline_storage”: false //Save when offline
Compile configuration file according to demands and save it as “dtu_config.json”, subsequently, save it to “dtu” folder in DTU codes library.
Note: Before saving json file, the annotation should be removed.
Download code to device
Connect to PC via data wire, press the “PWK” on the EVB to boot the device. After that, select the MI05 port in QPYcom.
port
Switch to the “Download” page, click “Create program” and name it.
Drag all files in “dtu” folder into the blank as described below. In addition, the figures are also involved.
Click the inverted triangle and select “Download script” till the end.
Transfer to “file” page and select “dtu_handler.py” on the right. It is available to debug and run dtu after clicking “Run” button. If there is a need to realize auto-run after power on, just rename the “dtu_handler.py” as “main.py”.
Reboot EVB
As above steps are done, select “USB MI05 COM Port”.(For old version, it is the USB serial port) and open it.
The DTU running is a success, the following figure shows the configuration file.
Message format
Command mode/ modubus mode
It supports transparency of multiple channels, binds channel and serial port via the serialID of configuration file. Each serial port supports binding multiple channels as well. When transmitting data, there is a need to import channel ID, meanwhile, the DTU will also transmit data to assigned channels.
In command and modbus modes, the received message will be analyzed by command firstly. Only the analysis is a failure can the data be transmitted to serial port.
Illustration on data format
HTTP/TCP/UDP
  • Message format of up-link data
"<channel_id>,<msg_len>"[,"<crc32>",”<msg_data>”]
  • Message format of down-link data
  • Field illustration
channel_id: Channel ID. To be specific, the channel ID in configuration file
msg_len: Message length in string format. Generally, the length can be 0.
crc32: CRC32 of message, when the msg_len is 0, this item can be neglected.
msg_data: Message data, when the msg_len is 0, this item can be neglected.
  • E. g.
Transmit message
“1,6,376e6e7,abcedf” (The length of msg_len is not 0 )
“1,0” (The length of msg_len is 0)
Return message
“5,2e46f5,20001”
MQTT/Aliyun/Txyun
  • The message format of up-link data
"<channel_id>,<topic_id>,<msg_len>","<crc32>",<msg_data>"
  • The message format of down-link data
topic_id: The topic_id of mqtt channel, the up-link means publishing topic id while the down-link means subscribing topic id.
crc32: CRC32 of message. This item can’t be neglected even if the msg_len is 0.
msg_data: Message data. This item can’t be neglected even if the msg_len is 0.
  • E. g.
Transmit message
“1,1,6,376e6e7,abcedf”
Return message
“1,1,5,2e46f5,20002”
Transparency mode
It supports the transparency of dual channel on MQTT/TCP/UDP/HTTP (Serial port 1& Serial port 2). In transparency mode, each serial port can be bound to one channel separately, which can be done via the serialID in configuration file. However, in transparency mode, if multiple channels are configured to serial port, only the first will be selected, as for the rest, just ignore.
For transparency mode, there is no need to import channel_id when transmitting since the DTU will transmit data to the serial port that bound with channel automatically.
HTTP/TCP/UDP
"<msg_len>"[,"<crc32>",”<msg_data>”]"
  • E. g.
Transmit message:
“6,376e6e7,abcedf” ( The length of msg_len is not 0)
“0” (The length of msg_len is 0)
Return message
“5,2e46f5,20001”
MQTT/Aliyun/Txyun
<topic_id>,<msg_len>,<crc32>,<msg_data>
crc32: CRC32 of message. This item can’t be neglected even if the the msg_len is 0.
  • E. g.
Transmit message
“6,376e6e7,abcedf”
Return message
“5,2e46f5,20002”
Communicate with Cloud via message
As for the communication between DTU and Cloud, the json format is used.
Down-link message of cloud
  • Command and modbus modes
{“msg_id”: msg_id, “data”: “1234”[, “cmd_code”: 0X40, “topic_id”: 1]}
  • Transparency mode
{“msg_id”: msg_id, “data”: “1234”}
msg_id: Message ID, which composed by time stamp and 3 random numbers normally
data: Filed of message
cmd_code: Selectable field. Fill in corresponding function code and make DTU carry out further operations. Please bear in mind that this field will take effect in command mode only.
topic_id: electable filed. When filling in mqtt, return the topic_id to be published. Similarly, this field will take effect in command mode or using MQTT/Aliyun/Txyun only.
Up-link message of cloud
{“msg_id”: msg_id, “data”: “1234”[, “cmd_code”: 0X40, “status”: 1]}
Transparency mode
msg_id: Message ID, which composed by time stamp and 3 random numbers normally. when replying message, the same msg_id will be used.
cmd_code: Selectable field, fill in corresponding function code make DTU carry out further operations. Please bear in mind that this field will take effect in command mode only .
status: Selectable field. it will take effect in command mode only, which is used to reply whether the execution is a success.
Example of MQTT on Aliyun
Connect device
In this case, the EC600N EVB and CP202 USB to TTL module are used to debug.
Connect to Tx, Rx and GND pins via 3 Dupont wires separately.
Connect the Tx of CP2102 to the RX0 pin of EC600N EVB (No.7), at the same time, link the Rx of CP2102 to the TX0 pin of EVB (No. 6). What’s more, attach the GND of DP2102 to the GND pin of the EVB (No. 1).
Connect the EVB and CP2102 to the PC separately, press PWK to boot.
Get connection parameter of Aliyun
There is a need for user to register account on Aliyun, create new program, register device name and get following parameters.
Devicename
ProductKey
DeviceSecret: The parameter should be provided when using unique-certificate-per-device authentication, as for unique-certificate-per-product authentication, the parameter is invisible.
ProductSecret: The parameter should be provided when using unique-certificate-per-product authentication, as for unique-certificate-per-device authentication, the parameter is invisible.
Get pk/ps of Aliyun
Get Device Name
Compile configuration file ans name it “dtu_config.json
What is involved in the configuration file.
“plate”: 1,
“password”: “123”,
“conf”: {
“1”: {
“type”: “mos”,
“keepAlive”: “”,
“clientID”: “0”,
“Devicename”: " ec600n",
“ProductKey”: " gbh26bFEA4M",
“DeviceSecret”: " b7ff5acc0671d40adfd0eff57e7605f6",
“cleanSession”: true,
“qos”: “1”,
“subscribe”: {“0”: " /gbh26bFEA4M/ec600n/user/subtest"},
“publish”: {“0”: " /gbh26bFEA4M/ec600n/user/pubtest"},
“serialID”: “0”
“reg”: 0,
“convert”: 0,
“version”: 100,
“nolog”: 0,
“message”: {},
“uconf”: {
“0”: {
“databits”: “8”,
“parity”: “0”,
“stopbits”: “1”,
“flowctl”: “0”
“fota”: 1,
“pins”: [
“pio1”,
“pio2”,
“pio3”
“apn”: [
“work_mode”: “through”,
“auto_connect”: 1,
Burn code
Connect the EVB to PC and start up. After that, open QPYcom, select Quectel USB MI05 port and click “connect” correspondingly.
qpycom_select_port
Switch to “Download” page, click ”Create program“, input its name and click “OK”.
Drag all files in dtu folder into the “user script/file” blank.
Click “Download script”
About Running
Switch to “File” page, select “dtu_handler.py” and click “Run”.
Output running result
Send message to cloud
Open serial port debug tool, select CP210X USB to UART, connect it to CP2102 board and open the serial port.
Import topic_id, msg_length, crc32 value and data should be sent to uart in accord with assigned format, then click “Send”.
After receiving data, the DTU will transmit it to cloud.
What received on cloud
cloud_recive
The cloud sends message to device
Send message to defined topic in the topic list of Aliyun.
The DTU receives message successfully and transmits data to serial port.
The transparency message received in serial port.
