[Document sharing]-Cloud Horn
About document
Revision history
Version Date Author Description
1.0 2021-09-15 Jaxsen Initial Version
Function introduction
  1. Detect access to network when starting up and switch network notifier.
  2. Connect server and detect server status regularly.
  3. Control the volume via GPIO
  4. Play tts audio
  5. Query history record
  6. Auto registration and reattachment
Usage
Get code
Code needs to be modified
Set the parameter of Aliyun server
Set “+/-" of the volume
  • Mode
    • Default volume mode
  • Volume mode key_mode=0
    • Set the gpio of “+” key, when there exists up/down edge event, it will trigger the volume+ mode
    • Set the gpio of “-” key, when there exists up/down edge event, it will trigger the volume- mode
  • Historical record mode key_mode=1
    • It will switch when the up/down edge event was triggered in key_fun, which will switched to historical info mode from volume mode.
    • It will broadcast the last historical trade record.
Set the GPIO of network notifier
  • Set the GPIO of network notifier
Run code
Run main.py code block on module
Set cloud server
Address: (aliyun.com)
Create product
Add device into corresponding product.
Self-defined topic
  • Query
  • Self-defined topic
  • Compile
  • Authority selection
    • Publish and subscribe
The connection is a success
Publish message
  • Click to publish
  • Deliver message
    • Message format
    • {“orderID”: 1,“productID”: 11111111,“msg”: "The Alipay is paid 1000 yuan ",“PayStatus”: 1,“createTime”: “2020/10/31 13:45:52”}
image-20220322165044
