DFOTA error 711 (BG77)
HI,
I am in the process of implementing DFOTA (BG77) but unfortunately I get every time:
+QIND: “FOTA”,“HTTPEND”,711
I tested it with HTTPS but also with HTTP
I use the following commands:
AT+QCFGEXT=“fota_apn”,1,“xx”,“”,“”
AT+CSQ;+CEREG?;+COPS?
+CSQ: 30,99
+CEREG: 2,5,“109”,“5751479”,8
+COPS: 0,2,“20416”,8
AT+QFOTADL=“xx”
+QIND: “FOTA”,“HTTPSTART”
Hi @JasperLI
Which SIM/network are you using? and have you set correct APN? according error code 711 means data call disconnect, So, this is probably your network issue.
