can I put the modem BG95-M2 to a continuous mode using the AT Commands? if yes which commands should I use to force CW mode?
Continuum mode? What am I supposed to understand about your continuum? Do you plan for the module to work continuously without interruption?
I am referring to Continuous Wave (CW) mode, where the module transmits a continuous, unmodulated RF signal for testing purposes.
I would like to know if the BG95-M2 supports CW transmission using AT commands. If yes, could you provide the correct command syntax?
If CW mode is not supported, is there an alternative way to generate a stable RF output for testing?
Thank you for your help!
According to my understanding, I have sent the FTM document to you, please check it
