Connection with aws cloud over lte is not working!
Hi ,
I am using BG95-M3 module. What i have observed that when i am able to register to gsm network , i am able to connect to the aws endpoint successfully. but when i am trying with another esim which is getting registered on eMTC(RAT8) , I am not able to connect to cloud. My connection to aws server is always failed. I am running the same piece of the code in both of the case . no change in code base.
Do i need to add more AT commands to make a successfully connection with aws cloud over emtc.
Regards
Vineet
Try these commands please.
at+creg?;+cereg?;+cgreg?
AT+QENG="SERVINGCELL"
AT+QIACT?
AT+CGPADDR
