@Bean.Wang-Q, @herbert.pan-Q
I am working on a project where I need to connect the Quectel EG21-GGB/EG25-GGB module to an eSIM (ST4SIM-200M_VFDFPN8). I would appreciate guidance on the following aspects:
1. Hardware Connection
- What are the recommended pin connections for interfacing the eSIM with the EG21-GGB/EG25-GGB?
- Are there any specific pull-up/pull-down resistors or level shifters needed?
- Does the module support 1.8V SIM card voltage directly, or are external components required?
2. Software Configuration
- What AT commands are necessary to configure the module to use the eSIM?
- How can I verify that the module recognizes the eSIM successfully?
- Are there any firmware updates or patches required for compatibility with eSIM?
3. eSIM Profile Management
- What is the process for downloading, activating, and switching eSIM profiles on this module?
- Are there APIs or AT commands for managing eSIM profiles?
4. Debugging and Troubleshooting
- What are the common issues faced during integration, and how can they be resolved?
- Is there a specific log or diagnostic tool to monitor eSIM-related activity in the module?
I am also interested in any application notes, reference designs, or documentation related to eSIM integration with Quectel modules.
Thank you for your support
