Configure EC200U to access one static IP address
I have been trying to configure ec200u such that it does not take any dynamic IP address to access the internet but so far it was unsuccessful. Can you kindly help to access the internet with one static IP address. Additionally, I did try to PPP dial but it replies with NO CARRIER.
I have been using these commands so far,
AT+CGDCONT=1,“IP”,“airteliot.com”,“xxx.xx.xx.xxx”
AT+CGATT=1
AT+CGACT =1,1
Even though I try to configure the address in AT+CGDCONT it changes as soon as the command AT+CGACT=1,1 is sent. IP address is displayed by using the command AT+CGPADDR
I have the IP address with me but I am not able to connect to EC200U using the same to access the internet. Additionally it is an M2M SIM card.
[2024-05-17 12:00:55:432_S:] AT+CGDCONT = 1,“IP”,“airteliot.com”,“xxx.xx.xx.xxx”
[2024-05-17 12:00:55:506_R:] AT+CGDCONT = 1,“IP”,“airteliot.com”,“xxx.xx.xx.xxx”
[2024-05-17 12:00:55:506_R:] OK
[2024-05-17 12:00:59:716_S:] AT+CGDCONT?
[2024-05-17 12:00:59:773_R:] AT+CGDCONT?
[2024-05-17 12:00:59:773_R:] +CGDCONT: 1,“IP”,“airteliot.com”,“xxx.xx.xx.xxx”,0,0
[2024-05-17 12:00:59:773_R:] OK
[2024-05-17 12:01:09:805_S:] AT+CGATT = 1
[2024-05-17 12:01:09:867_R:] AT+CGATT = 1
[2024-05-17 12:01:09:867_R:] OK
[2024-05-17 12:01:21:791_S:] AT+CGDCONT?
[2024-05-17 12:01:21:847_R:] AT+CGDCONT?
[2024-05-17 12:01:21:847_R:] +CGDCONT: 1,“IP”,“airteliot.com”,“xxx.xx.xx.xxx”,0,0
[2024-05-17 12:01:21:847_R:] OK
[2024-05-17 12:01:27:592_S:] AT+CGACT =1,1
[2024-05-17 12:01:27:656_R:] AT+CGACT =1,1
[2024-05-17 12:01:27:656_R:] OK
[2024-05-17 12:01:31:517_S:] AT+CGDCONT?
[2024-05-17 12:01:31:585_R:] AT+CGDCONT?
[2024-05-17 12:01:31:585_R:] +CGDCONT: 1,“IP”,“airteliot.com”,“yy.yy.yyy.yy”,0,0
[2024-05-17 12:01:31:585_R:] OK
The yy.yy.yyy.yy indicates the address change and xxx.xx.xx.xxx represents the static IP address given.
Any response is appreciated.
Hi @Navya_A
Static IP addresses are supported only by the SIM card, and cannot be fixed in the module.
Thank you for your response @lyman-Q but the network provider claims that they have assigned one IP address to the SIM card and they doubt that configuration is at fault from our side.
Is there any way I can change the configuration of EC200U or does EC200U by default take the static IP address of the SIM card?
