I use BG95-M3, I configured the PSM TAU to 1 minute and RAT to 30 seconds using the following AT commands. However, after waiting for several minutes, nothing happens. psm/urc is 1. Then I execute AT+QCFG=“psm/enter”,1 to force an immediate entry into PSM, there is still no output, and I do not see the “PSM POWER DOWN” message. Furthermore, the PSM_IND pin is consistently high.
-> AT+QCFG="psm/urc",1
-> AT+CPSMS=1,,,"01111110","00001111"
-> AT+CPSMS?
+CPSMS: 1,,,"01111110","00001111"
-> AT+QCFG="psm/enter",1
-> AT+QPSMCFG?
+QPSMCFG: 20,4
Additionally I tried changing the PSM version to 2 (in another topic somebody recommended doing so), it didn’t have any effect too:
for PSM to work it needs to be supported by the network. And in my experience the network seldom accepts the exact values requested.
Below are the AT commands I am using successfully with my BG95-M3.
(Please note: I am using the Quectel specific AT commands for PSM, eq QPx instead of CPx.)
// Disable PSM
AT+QPSMS=
// Check PSM - 0 means disabled
AT+QPSMS?
+QPSMS: 0,,,"14400","20"
// Enable PSM - ask for 60 s TAU and 30 s active timer
AT+QPSMS=1,,,"01111110","00001111"
// Check PSM - network agreed to 42 min TAU and 32 s active timer
AT+QPSMS?
+QPSMS: 1,,,"2520","32"
// about 32 seconds later modem goes into PSM
PSM POWER DOWN
Notes:
forcing PSM with AT+QCFG="psm/enter",1 does not work for me
when the modem is in PSM PSM_IND goes low
when the modem is in PSM the netlight also turns off
Thank you for your answer. I get this result when I use your AT commands:
AT+QPSMS=
AT+QPSMS?
+QPSMS: 0,,,,
AT+QPSMS?
+QPSMS: 1,,,,
It doesn’t show the accepted numbers. Nothing happens after this. Is it the network problem? if they are not supporting PSM, how can I save the power? I only send data, I don’t receive anything.
Can this approach replace PSM? AT+CFUN=0 and AT+CFUN=1 . Sometimes it takes a long time to connect to a network after this kind of power saving.
