I using this command to send SMS:
AT+CMGS=“999”
> Hello world <ctrl+z>// The result of sending the SMS takes a long time
So, can I cancel response? I cant write any AT Command when it not return result
AT+CMGS=“999”
hello, what’s your current firmware version?
My firmware is EC20CEHCLG
I saw a solution is press ESC to cancel operator. Do you know what ASCII number I need to send to port? Maybe 27?
The ASCII escape character 27 <ctrl+[> is an alternative to char 26 <ctrl+z> in the +CMGS command syntax. It aborts the command instead of attempting to send an SMS.
I doubt it would abort the sending, or perform any other function, after <ctrl+z> has already been given.
