BG96 will not connect to Soracom
@herbert.pan-Q
Thanks, let me try and get back to you with the result.
Thank you for the image, the upgraded module successfully connected to the internet with Soracom SIM.
My inquiry is now resolves,
thank you so much.
Hello @herbert.pan-Q
I’m having same issue.
I could not download from the above link.
Could you please upload BG96MAR03A04M1G_01.003.01.003.zip or later firmware?
Best regards.
I have sent it to your email
@herbert.pan-Q
Thank you so much.
@herbert.pan-Q
I have decided to give up on the broken BG96 and buy a new one.
Could you please tell me which version of the writing tool works properly with BG96MAR03A10M1G_01.001.01.001.zip?
best regards.
I have resend the tool and driver, please try again
Thank you for your repeated correspondence.
I tried to update the firmware again, but it failed.
I tried another module I have, and sixfab Cellular IoT HAT (with BG96) was able to update without any problems.
BG96 on P-L496G-CELL02 is BG96MA-128-SNN and BG96 on sixfab HAT is BG96MA-128-SGN.
Are these different and does this mean that the BG96MAR03… firmware is incompatible with the SNN model?
Best regards.
The link is broken
is it possible to update the link to the firmware..We really need it.
