Hello, is there any migration guide to switch EG915N from BG96? We have been trying to run X-CUBE-AZURE from ST using the modem at command code but we are having trouble to connecting the cloud. Is there any guide to apply the same code for EG915N?
Sorry I do not understand what commands do you want and what function did you migration from BG96.
I was wondering if a code written specifically for BG96 modem also work for EG915N? Is the procedure connecting to internet on EG915N any different from BG96? I am trying to run X-CUBE-AZURE from ST using EG915N which i made it work for BG96 but having trouble on EG915N. The code fails while trying to get IP address.
These two model are produce from different platform so it is not all of the code are compatible.
