The BG96 module is currently in use.
When I use the AT+QHTTPPOSTFILE command, I get 702 or 719 errors quite often. Is this a common problem with certain BG96 firmware? Is there a solution to this by changing the http setting through the AT command?
*For reference, the BG96 firmware version is using BG96MAR03A10M1G_01.001.01.001 and BG96MAR02A11M1G_01.16.01.016.
