BG955 cannot download file from FTP server
Hello. I am using BG955 with BG955AGLAAR02A01 firmware. The problem is with downloading FTP file from server using COM: port and ufs. I can query the size of the test file without problems. My file is test.txt file with “test” string inside. I can easily download this file on M65 and M66 modems but with BG955 i ran into following problems:
I can connect. I can query the size of the file. I cannot query the directory +QFTPPWD: 627,500 response.
I cannot download the file to output it to COM: port with AT+QFTPGET=“test.txt”,“COM:”,0
The CONNECT message never appears.
When i try to download it to UFS the +QFTPGET: 627,500 appears. Below are the logs.
09:02:52.798 -> AT+QIACT?
09:02:52.846 -> +QIACT: 1,1,1,"10.20.212.244"
09:02:52.846 ->
09:02:52.846 -> OK
09:03:01.626 -> AT+QFTPCFG="contextid",1
09:03:01.626 -> OK
09:03:08.524 -> AT+QFTPCFG="account","xxxx","xxxx"
09:03:08.524 -> OK
09:03:12.908 -> AT+QFTPCFG="filetype",1
09:03:12.908 -> OK
09:03:20.182 -> AT+QFTPCFG="transmode",1
09:03:20.182 -> OK
09:03:25.097 -> AT+QFTPCFG="rsptimeout",90
09:03:25.097 -> OK
09:03:30.058 -> AT+QFTPOPEN="xxxx.xxx,21
09:03:30.058 -> OK
09:03:33.979 ->
09:03:33.979 -> +QFTPOPEN: 0,0
09:03:47.718 -> AT+QFTPCWD="/FIRMWARE/"
09:03:47.718 -> OK
09:03:48.051 ->
09:03:48.051 -> +QFTPCWD: 0,0
09:04:19.418 -> AT+QFTPPWD
09:04:19.418 -> OK
09:04:27.498 ->
09:04:27.498 -> +QFTPPWD: 627,500
09:04:36.717 -> AT+QFTPSIZE="test.txt"
09:04:36.717 -> OK
09:04:38.325 ->
09:04:38.325 -> +QFTPSIZE: 0,4
09:04:50.282 -> AT+QFTPGET="test.txt","test2.txt",0
09:04:50.282 -> OK
09:04:52.740 ->
09:04:52.740 -> +QFTPGET: 627,500
The same procedure connecting to the same server can be easily done with m65 modem. Here i paste working m65 logs:
09:19:56.711 -> AT+QIACT
09:19:57.416 -> OK
09:20:29.476 -> AT+QFTPUSER="xxxxx"
09:20:29.476 -> OK
09:20:47.376 -> AT+QFTPPASS="xxxxx"
09:20:47.376 -> OK
09:20:57.535 -> AT+QFTPOPEN="xxxx.xx",21
09:20:57.535 -> OK
09:21:00.514 ->
09:21:00.514 -> +QFTPOPEN:0
09:21:17.848 -> AT+QFTPPATH="/FIRMWARE"
09:21:17.848 -> ERROR
09:21:33.994 -> AT+QFTPPATH="/FIRMWARE/"
09:21:34.042 -> OK
09:21:34.042 ->
09:21:34.042 -> +QFTPPATH:0
09:22:26.386 -> AT+QFTPSIZE="test.txt"
09:22:26.386 -> OK
09:22:27.140 ->
09:22:27.140 -> +QFTPSIZE:4
09:23:19.759 -> AT+QFTPGET="test.txt"
09:23:25.759 -> OK
09:23:27.036 ->
09:23:27.036 -> CONNECT
09:23:27.272 -> test
09:23:27.320 -> +QFTPGET:4
OR TO UFS:
09:29:46.011 -> at+qftpget="test.txt"
09:29:46.011 -> OK
09:29:47.524 ->
09:29:47.524 -> +QFTPGET:4
Also the commands response much faster on m65 modem than BG955. On BG955 i need to wait sometimes to connect to ftp while on m65 it happens pretty much instantly. What can i do, or what can i check to resolve this problem? Thank You. @Linkin-Q @herbert.pan-Q @Niki.Liu-Q
Hi @Adrian_Grygierczyk
Could you please try this latest fw version firstly? If issue still exist, please contact my email (linkin.wang@quectel.com)
Unfortunately i got newest firmware installed and it is not working.
Its working in my side. Is possible to provide your test server for us to checking?
Sent You email with test credentials
