The following problem can be reproduced in different firmware versions (i tested it with FW .200 / .201 / .204 and finally with BG95M3LAR02A03_A0.206.A0.206):
We use chipSIM cards from onomondo. If we want to provoke a network change, I have to change the network whitelist in onomondo and switch the SIM off and on again.
Initial situation: the MODEM is online in LTE-M and MQTT is connected. If I deactivate the SIM card in onomondo, CEREG=3 is reported, and immediately afterwards CEREG=5. But, according to Onomondo, the device is no longer connected.
If I query CEREG?, CEREG=5 is still reported. CREG? returns CREG=2. If I query the available networks with AT+QCOPS=2, I get no response. Only a further query after 5 minutes returns “No Service”
The MODEM cannot get out of this status on its own. Only with CFUN=0 and CFUN=1 does it start searching for networks again and a new connection is possible.
here are some (reduced) logs:
(18:23:03.219) BG95: TX(6ms): AT+QMTPUB=1,1,1,0,"bsiot/client/data/motion/--string-removed--",89<CR><LF>
(18:23:03.219) BG95: RX: AT+QMTPUB=1,1,1,0,"bsiot/client/data/motion/--string-removed--",89<CR><LF>
(18:23:03.219) BG95: RX: ><CR><LF>
(18:23:03.219) <CR><LF>
(18:23:03.219) BG95: TX(9ms): {"accX":-157,"accY":464,"accZ":9901,"angX":-305,"angY":-290,"angZ":183,"timestamp":32347}<CR><LF>
(18:23:03.219) BG95: RX: {"accX":-157,"accY":464,"accZ":9901,"angX":-305,"angY":-290,"angZ":183,"timestamp":32347}<CR><LF>
(18:23:03.219) BG95: RX: OK<CR><LF>
(18:23:03.423) BG95: RX: +QMTPUB: 1,1,0<CR><LF>
(18:23:03.423) LPWA: MQTT Publish status is 1<CR><LF>
(18:23:03.423) BG95: Enter Sleep Mode<CR><LF>
(18:24:00.602) BG95: RX: +CEREG: 3<CR><LF>
(18:24:00.602) BG95: RX: +QIURC: "pdpdeact",1<CR><LF>
(18:24:00.685) BG95: RX: +QMTSTAT: 1,1<CR><LF>
(18:24:00.685) LPWA: Active State: ACTIVE MQTT. Received URC QMTSTAT 1<CR><LF>
(18:24:00.685) BG95: Exit Sleep Mode<CR><LF>
(18:24:00.685) <CR><LF>
(18:24:00.685) BG95: TX(1ms): AT+CGMI=?<CR><LF>
(18:24:00.685) BG95: RX: AT+CGMI=?<CR><LF>
(18:24:00.685) BG95: RX: OK<CR><LF>
(18:24:00.685) BG95: TX(1ms): AT+QMTCONN?<CR><LF>
(18:24:00.685) BG95: RX: AT+QMTCONN?<CR><LF>
(18:24:00.685) LPWA: MQTT is not connected. So, Open and Connect to MQTT<CR><LF>
(18:24:00.685) BG95: Enter Sleep Mode<CR><LF>
(18:24:00.685) LPWA: Enter State: SETUP MQTT<CR><LF>
(18:24:00.767) BG95: RX: +CEREG: 5<CR><LF>
(18:24:00.767) LPWA: Event 26 ignored, State: SETUP MQTT<CR><LF>
(18:24:32.847) lpwa send AT+CFUN?<CR><LF>
(18:24:33.169) BG95: Exit Sleep Mode<CR><LF>
(18:24:33.169) CLI: Command succeed!<CR><LF>
(18:24:33.169) <CR><LF>
(18:24:33.169) BG95: TX(1ms): AT+CGMI=?<CR><LF>
(18:24:33.169) BG95: RX: AT+CGMI=?<CR><LF>
(18:24:33.169) BG95: RX: OK<CR><LF>
(18:24:33.169) BG95: TX(1ms): AT+CFUN?<CR><LF>
(18:24:33.169) BG95: Enter Sleep Mode<CR><LF>
(18:24:33.169) BG95: RX: AT+CFUN?<CR><LF>
(18:24:33.169) BG95: RX: +CFUN: 1<CR><LF>
(18:24:38.300) lpwa send AT+CREG?<CR><LF>
(18:24:38.585) BG95: Exit Sleep Mode<CR><LF>
(18:24:38.585) CLI: Command succeed!<CR><LF>
(18:24:38.585) <CR><LF>
(18:24:38.585) BG95: TX(1ms): AT+CGMI=?<CR><LF>
(18:24:38.585) BG95: RX: AT+CGMI=?<CR><LF>
(18:24:38.585) BG95: RX: OK<CR><LF>
(18:24:38.585) BG95: TX(1ms): AT+CREG?<CR><LF>
(18:24:38.585) BG95: Enter Sleep Mode<CR><LF>
(18:24:38.585) BG95: RX: AT+CREG?<CR><LF>
(18:24:38.585) BG95: RX: +CREG: 0,2<CR><LF>
(18:24:42.901) lpwa send AT+CEREG?<CR><LF>
(18:24:43.254) BG95: Exit Sleep Mode<CR><LF>
(18:24:43.254) CLI: Command succeed!<CR><LF>
(18:24:43.254) <CR><LF>
(18:24:43.254) BG95: TX(1ms): AT+CGMI=?<CR><LF>
(18:24:43.254) BG95: RX: AT+CGMI=?<CR><LF>
(18:24:43.254) BG95: RX: OK<CR><LF>
(18:24:43.254) BG95: TX(1ms): AT+CEREG?<CR><LF>
(18:24:43.254) BG95: Enter Sleep Mode<CR><LF>
(18:24:43.254) BG95: RX: AT+CEREG?<CR><LF>
(18:24:43.254) BG95: RX: +CEREG: 1,5<CR><LF>
(18:24:43.254) LPWA: Event 26 ignored, State: SETUP MQTT<CR><LF>
(18:24:53.291) lpwa send AT+QNWINFO<CR><LF>
(18:24:53.547) CLI: Command succeed!<CR><LF>
(18:24:53.547) BG95: Exit Sleep Mode<CR><LF>
(18:24:53.547) <CR><LF>
(18:24:53.547) BG95: TX(1ms): AT+CGMI=?<CR><LF>
(18:24:53.547) BG95: RX: AT+CGMI=?<CR><LF>
(18:24:53.547) BG95: RX: OK<CR><LF>
(18:24:53.547) BG95: TX(1ms): AT+QNWINFO<CR><LF>
(18:24:53.547) BG95: Enter Sleep Mode<CR><LF>
(18:24:53.547) BG95: RX: AT+QNWINFO<CR><LF>
(18:24:53.547) BG95: RX: +QNWINFO: "eMTC","26203","LTE BAND 20",6200<CR><LF>
(18:24:55.399) LPWA: MQTT connection state is NOT CONNECTED<CR><LF>
(18:24:55.399) ERROR: [0x2501] dcp publish failed<CR><LF>
(18:25:03.824) lpwa send AT+CSQ?<CR><LF>
(18:25:04.121) BG95: Exit Sleep Mode<CR><LF>
(18:25:04.121) CLI: Command succeed!<CR><LF>
(18:25:04.121) <CR><LF>
(18:25:04.121) BG95: TX(1ms): AT+CGMI=?<CR><LF>
(18:25:04.121) BG95: RX: AT+CGMI=?<CR><LF>
(18:25:04.121) BG95: RX: OK<CR><LF>
(18:25:04.121) BG95: TX(1ms): AT+CSQ?<CR><LF>
(18:25:04.121) BG95: Enter Sleep Mode<CR><LF>
(18:25:04.121) BG95: RX: AT+CSQ?<CR><LF>
(18:25:04.121) BG95: RX: +CME ERROR: 3<CR><LF>
(18:25:06.986) lpwa send AT+CSQ<CR><LF>
(18:25:07.291) CLI: Command succeed!<CR><LF>
(18:25:07.291) BG95: Exit Sleep Mode<CR><LF>
(18:25:07.291) <CR><LF>
(18:25:07.291) BG95: TX(1ms): AT+CGMI=?<CR><LF>
(18:25:07.291) BG95: RX: AT+CGMI=?<CR><LF>
(18:25:07.291) BG95: RX: OK<CR><LF>
(18:25:07.291) BG95: TX(0ms): AT+CSQ<CR><LF>
(18:25:07.291) BG95: Enter Sleep Mode<CR><LF>
(18:25:07.291) BG95: RX: AT+CSQ<CR><LF>
(18:25:07.291) BG95: RX: +CSQ: 19,99<CR><LF>
(18:25:26.957) lpwa send AT+QCOPS=2<CR><LF>
(18:25:27.272) CLI: Command succeed!<CR><LF>
(18:25:27.272) BG95: Exit Sleep Mode<CR><LF>
(18:25:27.272) <CR><LF>
(18:25:27.272) BG95: TX(1ms): AT+CGMI=?<CR><LF>
(18:25:27.272) BG95: RX: AT+CGMI=?<CR><LF>
(18:25:27.272) BG95: RX: OK<CR><LF>
(18:25:27.272) BG95: TX(1ms): AT+QCOPS=2<CR><LF>
(18:25:27.272) BG95: Enter Sleep Mode<CR><LF>
(18:25:27.272) BG95: RX: AT+QCOPS=2<CR><LF>
(18:32:04.206) lpwa send AT+QCOPS=2<CR><LF>
(18:32:04.545) BG95: Exit Sleep Mode<CR><LF>
(18:32:04.545) CLI: Command succeed!<CR><LF>
(18:32:04.545) <CR><LF>
(18:32:04.545) BG95: TX(1ms): AT+CGMI=?<CR><LF>
(18:32:04.545) BG95: RX: AT+CGMI=?<CR><LF>
(18:32:04.545) BG95: RX: OK<CR><LF>
(18:32:04.545) BG95: RX: +QCOPS: No Service<CR><LF>
(18:32:04.545) BG95: TX(1ms): AT+QCOPS=2<CR><LF>
(18:32:04.545) BG95: Enter Sleep Mode<CR><LF>
(18:32:04.545) BG95: RX: AT+QCOPS=2<CR><LF>
(18:38:42.345) lpwa send AT+CEREG?<CR><LF>
(18:38:42.630) BG95: Exit Sleep Mode<CR><LF>
(18:38:42.630) CLI: Command succeed!<CR><LF>
(18:38:42.630) <CR><LF>
(18:38:42.630) BG95: TX(1ms): AT+CGMI=?<CR><LF>
(18:38:42.630) BG95: RX: AT+CGMI=?<CR><LF>
(18:38:42.630) BG95: RX: OK<CR><LF>
(18:38:42.630) BG95: TX(1ms): AT+CEREG?<CR><LF>
(18:38:42.630) BG95: Enter Sleep Mode<CR><LF>
(18:38:42.630) BG95: RX: AT+CEREG?<CR><LF>
(18:38:42.630) BG95: RX: +CEREG: 1,5<CR><LF>
(18:38:42.630) LPWA: Event 26 ignored, State: SETUP MQTT<CR><LF>
(18:38:49.019) lpwa send AT+QNWINFO<CR><LF>
(18:38:49.302) CLI: Command succeed!<CR><LF>
(18:38:49.302) BG95: Exit Sleep Mode<CR><LF>
(18:38:49.302) <CR><LF>
(18:38:49.302) BG95: TX(1ms): AT+CGMI=?<CR><LF>
(18:38:49.302) BG95: RX: AT+CGMI=?<CR><LF>
(18:38:49.302) BG95: RX: OK<CR><LF>
(18:38:49.302) BG95: TX(1ms): AT+QNWINFO<CR><LF>
(18:38:49.302) BG95: Enter Sleep Mode<CR><LF>
(18:38:49.302) BG95: RX: AT+QNWINFO<CR><LF>
(18:38:49.302) BG95: RX: +QNWINFO: "eMTC","26203","LTE BAND 20",6200<CR><LF>
