BG95-M3 miniPCIE - MQTT protocol issues
Hello everybody,
I’m trying to use MQTT protocol based on BG95&BG77 MQTT Application Note document.
On 6.1 section there is an example to connect to AliCloud. This is the results:
AT+QMTCFG=“aliauth”,0,“oyjtmPl5a5j”,“MQTT_TEST”,“wN9Y6pZSIIy7Exa5qVzcmigEGO4kAazZ”
AT+QMTOPEN=?
+QMTOPEN: (0-5),“host_name”,(0-65535)
AT+QMTOPEN=0,“iot-as-mqtt.cn-shanghai.aliyuncs.com”,1883
+QMTOPEN: 0,0
AT+QMTOPEN?
+QMTOPEN: 0,“iot-as-mqtt.cn-shanghai.aliyuncs.com”,1883
AT+QMTCONN=?
+QMTCONN: (0-5),“clientID”[,“username”[,“password”]]
AT+QMTCONN=0,“clientExample”
ERROR
Why am I get error?
Another question: Is there a cloud broker that give visual information on messages I will post through the BG95 module?
Can it be an issue caused by firmware version?
BG95-M3
Revision: BG95M3LAR02A03
Thanks everybody.
Best Regards,
GS
Hi engkyr:
Sorry for late reply,The documentation is just an example, and you need to set up your own server if you want to test MQTT.
