BG95-M3 for DFOTA
Hi!
Is there a tool available to generate DFOTA files for the BG95-M3 module?
If the answer is yes, I would appreciate it if you could specify which tool it is and the procedure to follow in order to generate the file.
If the answer is no, what would be the alternative method to perform such actions to generate it?
Best regards,
Víctor Soler
Do you mean the DFOTA delta packet of the BG95M3 firmware? If so, you need to apply to us. You need to provide your current firmware version and the version you plan to upgrade
No, i mean a tool to generate our own DFOTA delta packet. We have a firmware with scripts combined in BG95-M3 module and, for example, fix a bug inside one of the scripts without sending all de .bin file over the air.
Are you using the openCPU version?
We don´t know what exactly means openCPU, but, we are working with BG95-M3 modul programed on QuecPython and with the tool QPYCom.
After internal consultation, for the DFOTA upgrade package of Qpy, you need to apply to the technical support team that assists you
Thank you very much for the prompt responses.
How can we get in touch with the technical support team?
Please contact with support@quectel.com
Could any of these options create a DFOTA package for the BG95-M3 module?
Hi VicSF
BG95 DFOTA upgrade can only upgrade the kernel. The DFOTA package can currently only be provided through us. If you only need to upgrade the script, you can use app_fota
app_fota - User File Upgrade - QuecPython
