Dear Support Team,
please can you send the release/change notes for the following firmware versions
BG95M3LAR02A03_01.204.01.204
BG95M3LAR02A03_01.204.01.205
BG95M3LAR02A03_01.204.01.206
Why: We have an issue with some of the BG95-M3 chips on our custom PCB have an older firmware that is not working for us.
BG95M3LAR02A03_01.204.01.204 - not working
BG95M3LAR02A03_01.204.01.206 - working
The symptom is:
AT+CMGF=1
ERROR
If we can see the release/change notes for each version we might be able to identify and work around the issue in our host(MCU) code.
If we need to update the firmware, I will need to contact you again to discuss as we can only access the BG95 via a soft/UART bridge running on our MCU (EPS32).
Thank you
