BG95-M2 Main-UART not working
Hi all,
I’m currently testing a selfmade PCB using a BG95-M2 module.
It works almost as expected when using the USB interface.
I can send AT commands and get an answer.
But the main application is to control everything via UART through a microcontroller and this does not work at all.
By using an oscilloscope I can’t see any signal activity on MAIN_TXD.
I tried a BG95-M3 Module before and immediately after power-up it outputs “RDY” and “APP RDY” on the UART.
I thought -M2 und -M3 should behave exactly the same, but it seems it does not.
The -M2 version is also active (CFUN=1) immediately after power-up, while the -M3 is not.
Output of BG95-M2 via USB after power-up:
RDY
+CFUN: 1
+CPIN: READY
+QUSIM: 1
+QIND: SMS DONE
APP RDY
ATI
BG95-M2
Revision: BG95M2LAR02A04
AT+QGMR
BG95M2LAR02A04_01.003.02.003
Output of BG95-M3 via UART after power-up:
RDY
APP RDY
ATI
BG95-M3
Revision: BG95M3LAR02A03
Schematic
Any ideas ?
Do I need a different firmware ?
Best regards,
lakeroe
It seems that RTS and CTS are floating. Maybe you can short them to the GND.
in the meantime I ordered and tested another BG95-M2 module and I think I found the problem.
Working BG95-M2 module
AT+QGMR
BG95M2LAR02A04_A0.301.A0.301
NOT Working BG95-M2 module
AT+QGMR
The hardware setup for both modules is exactly the same, so the only difference is the firmware.
Can you please send me the firmware of the working module, so I can update the none-working one and confirm this issue ?
Many thanks,
lakeroe
