BG95 firmware update
Hello. My BG95-M3 is crashing from times to times (shutting down while I am sending commands too fast). May I ask you to indicate me location of latest firmware ? (I am going to move to BG95-S5 then so please send me a version that is as close as possible despite missing features in S5. I already stopped to use QLTS & QLBS. Please indicate if there is other groups of commands not available.) Thank you.
Could you please tell me the current detailed version?
AT+QGMR
BG95M3LAR02A03_01.005.01.005
Thank you
I have send you the latest version and check your email please.
Hello
Thank you
i could understand that I need qfirehose to perform update:
git clone https://github.com/nippynetworks/qfirehose
autoscan && autoreconf --install
./configure
make
sudo ./QFirehose -f ../BG95_firmware/ -p /dev/ttyUSB0
It does not work. May I ask you a firmware update guide ?
Thank you
[000.000]: Version: QFirehose_Linux_Android_V1.4.17
[000.000]: Builded: Dec 1 2024 20:56:39
[000.000]: Find md5 check file <../BG95_firmware/md5.txt>
[000.000]: md5 checking: ../BG95_firmware/dam/recover/firehose/partition_complete_p2K_b128K.mbn pass
[000.000]: md5 checking: ../BG95_firmware/dam/recover/firehose/patch_p2K_b128K.xml pass
[000.001]: md5 checking: ../BG95_firmware/dam/recover/firehose/prog_firehose_nand_mdm9x05.elf pass
[000.001]: md5 checking: ../BG95_firmware/dam/recover/firehose/rawprogram_nand_p2K_b128K_dam_recover.xml pass
[000.001]: md5 checking: ../BG95_firmware/dam/update/firehose/partition_complete_p2K_b128K.mbn pass
[000.001]: md5 checking: ../BG95_firmware/dam/update/firehose/patch_p2K_b128K.xml pass
[000.002]: md5 checking: ../BG95_firmware/dam/update/firehose/prog_firehose_nand_mdm9x05.elf pass
[000.002]: md5 checking: ../BG95_firmware/dam/update/firehose/rawprogram_nand_p2K_b128K_dam.xml pass
[000.002]: md5 checking: ../BG95_firmware/mbn/common/ROW/Commercial/mcfg_sw.mbn pass
[000.002]: md5 checking: ../BG95_firmware/mbn/EU/DT/DT/mcfg_sw.mbn pass
[000.002]: md5 checking: ../BG95_firmware/mbn/EU/Telefonica/telefonica/mcfg_sw.mbn pass
[000.002]: md5 checking: ../BG95_firmware/mbn/EU/Vodafone/vodafone/mcfg_sw.mbn pass
[000.002]: md5 checking: ../BG95_firmware/mbn/NA/ATT/FirstNet/mcfg_sw.mbn pass
[000.002]: md5 checking: ../BG95_firmware/mbn/NA/ATT/Non_VoLTE/mcfg_sw.mbn pass
[000.002]: md5 checking: ../BG95_firmware/mbn/NA/Rogers/rogers/mcfg_sw.mbn pass
[000.002]: md5 checking: ../BG95_firmware/mbn/NA/Telus/telus_consumer/mcfg_sw.mbn pass
[000.002]: md5 checking: ../BG95_firmware/mbn/NA/Telus/telus_jasper/mcfg_sw.mbn pass
[000.002]: md5 checking: ../BG95_firmware/mbn/NA/TMO/Commercial/mcfg_sw.mbn pass
[000.002]: md5 checking: ../BG95_firmware/mbn/NA/VERIZON/IMSless/mcfg_sw.mbn pass
[000.003]: md5 checking: ../BG95_firmware/qsr4/msg_hash_271d8d49-5c4f-bc48-beba-9c5a573c70ce.qsr4 pass
[000.013]: md5 checking: ../BG95_firmware/qsr4/msg_hash_b67f6f30-198a-407a-8fde-26e72e72c3ed.qsr4 pass
[000.020]: md5 checking: ../BG95_firmware/update/apps.mbn pass
[000.020]: md5 checking: ../BG95_firmware/update/cmnlib.mbn pass
[000.020]: md5 checking: ../BG95_firmware/update/devcfg.mbn pass
[000.020]: md5 checking: ../BG95_firmware/update/firehose/partition.mbn pass
[000.020]: md5 checking: ../BG95_firmware/update/firehose/partition_nand.xml pass
[000.020]: md5 checking: ../BG95_firmware/update/firehose/patch_p2K_b128K.xml pass
[000.021]: md5 checking: ../BG95_firmware/update/firehose/prog_firehose_nand_mdm9x05.elf pass
[000.021]: md5 checking: ../BG95_firmware/update/firehose/rawprogram_nand_p2K_b128K.xml pass
[000.021]: md5 checking: ../BG95_firmware/update/keymasterapp32.mbn pass
[000.021]: md5 checking: ../BG95_firmware/update/multi_image.mbn pass
[000.021]: md5 checking: ../BG95_firmware/update/multi_image_qti.mbn pass
[000.021]: md5 checking: ../BG95_firmware/update/partition_complete_p2K_b128K.mbn pass
[000.039]: md5 checking: ../BG95_firmware/update/qdsp6sw.mbn pass
[000.044]: md5 checking: ../BG95_firmware/update/qdsp6sw_2.mbn pass
[000.053]: md5 checking: ../BG95_firmware/update/qdsp6sw_paging.bin pass
[000.054]: md5 checking: ../BG95_firmware/update/rpm.mbn pass
[000.055]: md5 checking: ../BG95_firmware/update/sbl1.mbn pass
[000.055]: md5 checking: ../BG95_firmware/update/sec.elf pass
[000.056]: md5 checking: ../BG95_firmware/update/tz.mbn pass
[000.056]: Totals checking 40 files md5 value, 0 file fail!
[000.056]: find ‘prog_firehose_nand_mdm9x05.elf’
[000.056]: find_firehose_mbn prog_firehose_nand_mdm9x05.elf
[000.057]: qusb_read_speed_atime speed: 12, st_atime: 20241201_20:43:19
[000.057]: P: /dev/bus/usb/001/004 idVendor=0403 idProduct=6001
[000.057]: C: /dev/bus/usb/001/004 bNumInterfaces: 1
[000.057]: I: If#= 0 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=ff
[000.057]: E: Ad=81 Atr=02 MxPS= 64 Ivl=0ms
[000.057]: E: Ad=02 Atr=02 MxPS= 64 Ivl=0ms
[000.057]: tmp=/sys/bus/usb/devices/usb1/../driver, driver=../../../bus/pci/drivers/xhci_hcd
[000.057]: qusb_noblock_open port_name = /dev/ttyUSB0
[000.065]: retrieve NPRG MBN failed.
[000.071]: Upgrade module failed.
I could make some progress having the device powered by an external power supply.
Still device shuts down during upgrade.
sudo ./qfirehose/QFirehose -f BG95_firmware/
[000.000]: Find md5 check file <BG95_firmware/md5.txt>
[000.000]: md5 checking: BG95_firmware/dam/recover/firehose/partition_complete_p2K_b128K.mbn pass
[000.000]: md5 checking: BG95_firmware/dam/recover/firehose/patch_p2K_b128K.xml pass
[000.001]: md5 checking: BG95_firmware/dam/recover/firehose/prog_firehose_nand_mdm9x05.elf pass
[000.001]: md5 checking: BG95_firmware/dam/recover/firehose/rawprogram_nand_p2K_b128K_dam_recover.xml pass
[000.001]: md5 checking: BG95_firmware/dam/update/firehose/partition_complete_p2K_b128K.mbn pass
[000.001]: md5 checking: BG95_firmware/dam/update/firehose/patch_p2K_b128K.xml pass
[000.002]: md5 checking: BG95_firmware/dam/update/firehose/prog_firehose_nand_mdm9x05.elf pass
[000.002]: md5 checking: BG95_firmware/dam/update/firehose/rawprogram_nand_p2K_b128K_dam.xml pass
[000.002]: md5 checking: BG95_firmware/mbn/common/ROW/Commercial/mcfg_sw.mbn pass
[000.002]: md5 checking: BG95_firmware/mbn/EU/DT/DT/mcfg_sw.mbn pass
[000.002]: md5 checking: BG95_firmware/mbn/EU/Telefonica/telefonica/mcfg_sw.mbn pass
[000.002]: md5 checking: BG95_firmware/mbn/EU/Vodafone/vodafone/mcfg_sw.mbn pass
[000.002]: md5 checking: BG95_firmware/mbn/NA/ATT/FirstNet/mcfg_sw.mbn pass
[000.002]: md5 checking: BG95_firmware/mbn/NA/ATT/Non_VoLTE/mcfg_sw.mbn pass
[000.002]: md5 checking: BG95_firmware/mbn/NA/Rogers/rogers/mcfg_sw.mbn pass
[000.002]: md5 checking: BG95_firmware/mbn/NA/Telus/telus_consumer/mcfg_sw.mbn pass
[000.002]: md5 checking: BG95_firmware/mbn/NA/Telus/telus_jasper/mcfg_sw.mbn pass
[000.002]: md5 checking: BG95_firmware/mbn/NA/TMO/Commercial/mcfg_sw.mbn pass
[000.002]: md5 checking: BG95_firmware/mbn/NA/VERIZON/IMSless/mcfg_sw.mbn pass
[000.004]: md5 checking: BG95_firmware/qsr4/msg_hash_271d8d49-5c4f-bc48-beba-9c5a573c70ce.qsr4 pass
[000.013]: md5 checking: BG95_firmware/qsr4/msg_hash_b67f6f30-198a-407a-8fde-26e72e72c3ed.qsr4 pass
[000.018]: md5 checking: BG95_firmware/update/apps.mbn pass
[000.019]: md5 checking: BG95_firmware/update/cmnlib.mbn pass
[000.019]: md5 checking: BG95_firmware/update/devcfg.mbn pass
[000.019]: md5 checking: BG95_firmware/update/firehose/partition.mbn pass
[000.019]: md5 checking: BG95_firmware/update/firehose/partition_nand.xml pass
[000.019]: md5 checking: BG95_firmware/update/firehose/patch_p2K_b128K.xml pass
[000.020]: md5 checking: BG95_firmware/update/firehose/prog_firehose_nand_mdm9x05.elf pass
[000.020]: md5 checking: BG95_firmware/update/firehose/rawprogram_nand_p2K_b128K.xml pass
[000.020]: md5 checking: BG95_firmware/update/keymasterapp32.mbn pass
[000.020]: md5 checking: BG95_firmware/update/multi_image.mbn pass
[000.020]: md5 checking: BG95_firmware/update/multi_image_qti.mbn pass
[000.020]: md5 checking: BG95_firmware/update/partition_complete_p2K_b128K.mbn pass
[000.038]: md5 checking: BG95_firmware/update/qdsp6sw.mbn pass
[000.043]: md5 checking: BG95_firmware/update/qdsp6sw_2.mbn pass
[000.052]: md5 checking: BG95_firmware/update/qdsp6sw_paging.bin pass
[000.053]: md5 checking: BG95_firmware/update/rpm.mbn pass
[000.054]: md5 checking: BG95_firmware/update/sbl1.mbn pass
[000.054]: md5 checking: BG95_firmware/update/sec.elf pass
[000.055]: md5 checking: BG95_firmware/update/tz.mbn pass
[000.055]: Totals checking 40 files md5 value, 0 file fail!
[000.055]: find ‘prog_firehose_nand_mdm9x05.elf’
[000.055]: find_firehose_mbn prog_firehose_nand_mdm9x05.elf
[000.055]: [1] /sys/bus/usb/devices/1-1 2c7c/700/0
[000.055]: qusb_read_speed_atime speed: 480, st_atime: 20241201_21:44:51
[000.055]: P: /dev/bus/usb/001/011 idVendor=2c7c idProduct=0700
[000.055]: C: /dev/bus/usb/001/011 bNumInterfaces: 4
[000.055]: I: If#= 0 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=ff
[000.055]: E: Ad=81 Atr=02 MxPS= 512 Ivl=0ms
[000.055]: E: Ad=01 Atr=02 MxPS= 512 Ivl=0ms
[000.055]: I: If#= 1 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=ff
[000.055]: E: Ad=82 Atr=02 MxPS= 512 Ivl=0ms
[000.055]: E: Ad=02 Atr=02 MxPS= 512 Ivl=0ms
[000.055]: I: If#= 2 Alt= 0 #EPs= 3 Cls=ff Sub=ff Prot=ff
[000.055]: E: Ad=83 Atr=03 MxPS= 64 Ivl=5ms
[000.055]: E: Ad=84 Atr=02 MxPS= 512 Ivl=0ms
[000.055]: E: Ad=03 Atr=02 MxPS= 512 Ivl=0ms
[000.055]: I: If#= 3 Alt= 0 #EPs= 3 Cls=ff Sub=ff Prot=ff
[000.055]: E: Ad=85 Atr=03 MxPS= 64 Ivl=5ms
[000.055]: E: Ad=86 Atr=02 MxPS= 512 Ivl=0ms
[000.055]: E: Ad=04 Atr=02 MxPS= 512 Ivl=0ms
[000.055]: tmp=/sys/bus/usb/devices/usb1/../driver, driver=../../../bus/pci/drivers/xhci_hcd
[000.055]: qusb_noblock_open port_name = /dev/ttyUSB0
[003.062]: poll_wait events=POLLIN msec=3000 timeout
[003.062]: qfirehose.c detect_and_judge_module_version 251 fail
[004.066]: poll_wait events=POLLIN msec=1000 timeout
[004.066]: switch to ‘Emergency download mode’
[004.071]: successful, wait module reboot
[005.084]: P: /dev/bus/usb/001/011 idVendor=2c7c idProduct=0700
[005.084]: C: /dev/bus/usb/001/011 bNumInterfaces: 4
[005.084]: I: If#= 0 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=ff
[005.084]: E: Ad=81 Atr=02 MxPS= 512 Ivl=0ms
[005.084]: E: Ad=01 Atr=02 MxPS= 512 Ivl=0ms
[005.084]: I: If#= 1 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=ff
[005.084]: E: Ad=82 Atr=02 MxPS= 512 Ivl=0ms
[005.084]: E: Ad=02 Atr=02 MxPS= 512 Ivl=0ms
[005.084]: I: If#= 2 Alt= 0 #EPs= 3 Cls=ff Sub=ff Prot=ff
[005.084]: E: Ad=83 Atr=03 MxPS= 64 Ivl=5ms
[005.084]: E: Ad=84 Atr=02 MxPS= 512 Ivl=0ms
[005.084]: E: Ad=03 Atr=02 MxPS= 512 Ivl=0ms
[005.084]: I: If#= 3 Alt= 0 #EPs= 3 Cls=ff Sub=ff Prot=ff
[005.084]: E: Ad=85 Atr=03 MxPS= 64 Ivl=5ms
[005.084]: E: Ad=86 Atr=02 MxPS= 512 Ivl=0ms
[005.084]: E: Ad=04 Atr=02 MxPS= 512 Ivl=0ms
[005.084]: tmp=/sys/bus/usb/devices/usb1/../driver, driver=../../../bus/pci/drivers/xhci_hcd
[005.084]: qusb_noblock_open port_name = /dev/ttyUSB0
[007.885]: qusb_noblock_read read=0, errno: 0 (Success)
[007.885]: qusb_noblock_read cur=0, min_size=1
[007.885]: qfirehose.c detect_and_judge_module_version 251 fail
[007.885]: switch to ‘Emergency download mode’
[007.885]: qusb_noblock_write write=-1, errno: 5 (Input/output error)
[007.885]: qusb_noblock_write cur=0, min_size=7
[007.885]: qusb_noblock_read read=0, errno: 5 (Input/output error)
[008.891]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
[009.894]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
[010.895]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
[011.898]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
[012.900]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
[013.900]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
[014.903]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
[015.924]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
[016.924]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
^C
PS: I am running this under virtualbox 7.0 / Ubuntu 18.04.6 LTS
Thank you
I have send you the upgrade guide and If the firmware upgrade fails,then the log files MCU_remote.log.txt and Ubuntu_remote.log.txt under directory log in the tool package can be used to help failure analysis.
Hello
Thank you for the guide. It seems that the step 3 is no OK.
I do not see VID is 0x05c6 but see VID is 0x2c7c twice.
Device shuts down and communication is stopped.
Thank you.
[000.197]: Totals checking 40 files md5 value, 0 file fail!
[000.197]: find ‘prog_firehose_nand_mdm9x05.elf’
[000.197]: find_firehose_mbn prog_firehose_nand_mdm9x05.elf
[000.197]: [1] /sys/bus/usb/devices/1-1 2c7c/700/0
[000.197]: qusb_read_speed_atime speed: 480, st_atime: 20241202_10:58:01
[000.197]: P: /dev/bus/usb/001/002 idVendor=2c7c idProduct=0700
[000.197]: C: /dev/bus/usb/001/002 bNumInterfaces: 4
[000.197]: I: If#= 0 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=ff
[000.197]: E: Ad=81 Atr=02 MxPS= 512 Ivl=0ms
[000.197]: E: Ad=01 Atr=02 MxPS= 512 Ivl=0ms
[000.197]: I: If#= 1 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=ff
[000.197]: E: Ad=82 Atr=02 MxPS= 512 Ivl=0ms
[000.197]: E: Ad=02 Atr=02 MxPS= 512 Ivl=0ms
[000.197]: I: If#= 2 Alt= 0 #EPs= 3 Cls=ff Sub=ff Prot=ff
[000.198]: E: Ad=83 Atr=03 MxPS= 64 Ivl=5ms
[000.198]: E: Ad=84 Atr=02 MxPS= 512 Ivl=0ms
[000.198]: E: Ad=03 Atr=02 MxPS= 512 Ivl=0ms
[000.198]: I: If#= 3 Alt= 0 #EPs= 3 Cls=ff Sub=ff Prot=ff
[000.198]: E: Ad=85 Atr=03 MxPS= 64 Ivl=5ms
[000.198]: E: Ad=86 Atr=02 MxPS= 512 Ivl=0ms
[000.198]: E: Ad=04 Atr=02 MxPS= 512 Ivl=0ms
[000.198]: tmp=/sys/bus/usb/devices/usb1/../driver, driver=../../../bus/pci/drivers/xhci_hcd
[000.198]: qusb_noblock_open port_name = /dev/ttyUSB0
[000.203]: old software version: BG95M3LAR02A03
[001.214]: poll_wait events=POLLIN msec=1000 timeout
[001.214]: switch to ‘Emergency download mode’
[001.218]: successful, wait module reboot
[002.238]: P: /dev/bus/usb/001/002 idVendor=2c7c idProduct=0700
[002.238]: C: /dev/bus/usb/001/002 bNumInterfaces: 4
[002.238]: I: If#= 0 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=ff
[002.238]: E: Ad=81 Atr=02 MxPS= 512 Ivl=0ms
[002.238]: E: Ad=01 Atr=02 MxPS= 512 Ivl=0ms
[002.238]: I: If#= 1 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=ff
[002.238]: E: Ad=82 Atr=02 MxPS= 512 Ivl=0ms
[002.238]: E: Ad=02 Atr=02 MxPS= 512 Ivl=0ms
[002.238]: I: If#= 2 Alt= 0 #EPs= 3 Cls=ff Sub=ff Prot=ff
[002.238]: E: Ad=83 Atr=03 MxPS= 64 Ivl=5ms
[002.238]: E: Ad=84 Atr=02 MxPS= 512 Ivl=0ms
[002.238]: E: Ad=03 Atr=02 MxPS= 512 Ivl=0ms
[002.238]: I: If#= 3 Alt= 0 #EPs= 3 Cls=ff Sub=ff Prot=ff
[002.238]: E: Ad=85 Atr=03 MxPS= 64 Ivl=5ms
[002.238]: E: Ad=86 Atr=02 MxPS= 512 Ivl=0ms
[002.238]: E: Ad=04 Atr=02 MxPS= 512 Ivl=0ms
[002.238]: tmp=/sys/bus/usb/devices/usb1/../driver, driver=../../../bus/pci/drivers/xhci_hcd
[002.239]: qusb_noblock_open port_name = /dev/ttyUSB0
[004.348]: qusb_noblock_read read=0, errno: 0 (Success)
[004.348]: qusb_noblock_read cur=0, min_size=1
[004.348]: switch to ‘Emergency download mode’
[004.348]: qusb_noblock_write write=-1, errno: 5 (Input/output error)
[004.348]: qusb_noblock_write cur=0, min_size=7
[004.348]: qusb_noblock_read read=0, errno: 5 (Input/output error)
[005.369]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
[006.375]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
[007.379]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
[008.381]: fail to fopen /sys/bus/usb/devices/1-1/uevent, errno: 2 (No such file or directory)
If the device at 1-1 is not connected to the computer,the uevent file will not exist.Run the following command to see the list of USB devices and their corresponding paths:ls /sys/bus/usb/devices/.
Hello
Device crashes and shut down. All led OFF except power supply. so I expect usb stack to update and remove unreachable peripherals.
So error is not on usb side but on module one when going into “emergency download mode”. I can see idVendor two times at 2c7c and guide you sent me does not describe that behavior.
Any hint ? maybe use an older version of qfirehose ? I am using git I can go back to version 1.4.9 and version 1.2.
Hello, maybe you can try another real PC.
If you insist on the virtualbox or vmware, we cannot promise that you can succeed to flash.
If you still want to try the QFirehose on Virtual machine.
You can try
Once you see the
Then connect the device into the virtual machine again. And try run the QFirehose again.
The USB VID/PID should be
05c6/9008.
Hello, my BG95-M3 has the firmware
at+gmr
BG95M3LAR02A03
Please send me the current firmware and the upgrade guide. I use the module with a raspberry pi 4.
Thanks a lot.
Martin
AT+QGMR
BG95M3LAR02A03_A0.206.A0.206
I could finally have the update be performed using Ubuntu 18.04 LTS real PC. Device shut down but upgrade continues.
Thank you.
Let’s see if our bugs are still here now !
