Can I have the schematics PDF for BG77xA-GL TE-B including the BOM and if possible source Altium/Allegro/… documents for the PCB and Schematics?
Regards
Regards
Please check the BG770A-GL-TE-B_SCH_V1.2_20230626.
We cannot send the BOM.
Dear Bean.Wang-Q!
I have a similar problem where I need to know where the Main UART Rx/Tx are located. I want to connect them to my test MCU. There is an RXD and TXD pins but without the schematic I don’t know if it will work without a trial. I found the VDD_EXT and I can connect it to my voltage-level translator. I’m using a V1.2 TE-B board. The user manual says the RXD and TXD in the J0604 Test Points. Is there any description about these test points at least?
Thank you in advance!
Mat
Correction: *The user manual mentions the UART RXD and TXD pins which are inside the J06014 Test Points.
