I am using EPAT to capture logs from BG770A-GL module (version BG770AGLAAR01A05_01.200.01.200), but the logs are formatted in hex.
So how can I get the database update text file?
Thanks in advance.
BG770A-GL using QserialLog tool to capture logs.
Hi @Linkin-Q
Sure, I am using the QserialLog tool to record logs, but they are in hex format. Therefore, I use the EPAT tool to decode these logs. However, the EPAT tool requires an updated database file.
HI @BK_Electronic
EPAT cant decode this log, there is need PCtools to decode it.
