BG600L QueckPtyhon to Default firmware
If I load the QuecPython firmware onto the BG600L module, will I still be able to control the module via AT commands over the RX/TX pins, or does this functionality disappear with the QuecPython firmware?
Additionally, can you provide me with the relevant documentation and firmware files needed to restore the module to factory settings after installing the QuecPython firmware?
Thank you!
hi
in quecpython,We recommend using the API for debugging because most of the AT is cropped.
For usage of the API, please refer to the links below
QuecPython API Reference Manual - QuecPython
