I’m trying to reduce the power consumption of the BC95-G to the stated 5uA in the datasheet, but the best I have got is around 677 - 680 uA. I enabled the PSM URC and I can see that it enters PSM successfully. Any ideas as to why it could be not working?
Here is the output of ATI:
BC95-G
Revision:BC95GJBR01A07
With the modem turned off, the power consumption of the PCBA is around 35uA. It is possible that I have not set the UART pins connected to the modem correctly, when putting the main MCU to sleep. I’ll look into this.
