patrech
November 8, 2021, 7:36am
#1
I use the BC660k modul and will upload the certificate to the modul to connect it with the aws(amazon web service) but i don`t find the correct AT-cmd for that.
With BC96 modul the comman is:
AT+QFUPL=“name_of_the_file”,,…
Exist for the BC660k an alternative?
hi,patrech:
I suggest you refer to BG96’s AT Commad about FILE Operation.If there are any questions, we will continue to communicate.
patrech
November 8, 2021, 9:36am
#3
Hi herbert
The problem is that this At commands don’t exit with the BC660K modul.
or am I making a mistake?
I’m very sorry, By my test, BC660K does not support QFUPL.I recommend you manually enter the certificate content.
hi,iot1:
QCOM_V1.6.zip (715.5 KB)
1、Display “connect ” information;
2、Select your CA certificate file and import it;
3、Display your CA certificate file path and file name;
4、Send and upload CA file.
[image]
patrech
November 8, 2021, 10:05am
#5
Hi Herbert
So is there no opportunity to upload the CA certificate, on the BC660k?
Yes, file manipulation is not currently supported and your CA certificate cannot be saved in the file system.
