Hi
I’m trying to debug a BC660K module that doesn’t connect to network.
Running the EPAT tool I receive log messages from module but the tool doesn’t decode them.
Firmware version received from module is:
“Quectel_Ltd
Quectel_BC660K-GL
Revision: BC660KGLAAR01A05_01.200.01.200”
I’m using the correct version of comdb file for this firmware revision and when I connect another module with the same firmware version the EPAT tool works fine.
Can you try to decode the file on your side?
comdb.txt (1.5 MB)
20260209_094339.zip (1.9 MB)
