Hello,
i have problems with the debug output.
I configured baud rate 115200 and port7 is interface2.
You can use quectel serial tool QCOM to compare and test.
Can you send me the download link?
I just tried it again with a new BC66-TE-B board.
What i did:
- connect the board via usb to the pc
- checked interface port -> COM10 for interface2
- opened putty on com10 with baudrate 115200
As you can see i still have the same problems.
You need to use the genie tool provided by MTK to capture the module debug port log, you can send an email to support@quectel.com for more help.
The interface 2 would not print what you want. You should use the interace 0.
the problem maybe is windows driver for new TE-A board
Hello WizIO
i have read your github and watched the videos on youtube. I am new to BC66 and PlatfromIO,did you have a self blog or any guide about PlatformIO.
Sincerly thanks.
the blog is blah blah
PlatformIO doc is here
https://docs.platformio.org/en/latest/projectconf/section_env_build.html
in principle it is Phyton builder ( as make, cmake ) and is plugin for VSCode
as example for BC66 opencpu script
or just ask in forum
