We have connected the EK79007 display to the Quectel SC668S and performed the following steps to configure it:
Added the display timings and necessary commands in the device tree.
Flashed the updated image. However, the issue is that the Quectel SC668S SOM displays the “Quectel logo image,” but when the Android screen loads, the screen timings are incorrect, and the display does not render properly.
If the display goes to sleep and then wakes up, the Android home screen appears correctly, and the display functions as expected.
We suspect that the timing configurations need to be added to the bootloader. However, after analyzing the code, we could not find any panel-related configurations. We were informed that the Quectel team might have access to update the timing. Could you confirm whether the timing update needs to be done by your team, or if we can modify the code ourselves?
